LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,312
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
having to use sledge hammers or loosen lug nuts and drive in figure 8's to try and break a wheel free.I haven't had to ever use a sledge to remove a lugnut in the north.
I have had to use a sledge and then add a portapower to the mix to remove an inside rear dual wheel that was frozen on from rust and corrosion.
To get back to tractors did a tire swap last fall on this tractor, the first picture I had worked on that wheel 4-5 years ago, came apart just like it should have, the second picture I was replacing the bolts that held the center to the outer wheel, that was a 3 day project that involved penetrating oil, heat, and a 3/4 drive breaker bar with an extension pipe and then after replacing the outer bolts it took driving the tractor and making several sharp turns and figure 8's with the center lug nut loosened considerable to get the center free of the hub. In preparation for replacing the outer wheel.
nice shiney outer wheel and the hub and all wheel bolts and lug nuts have been anti seized.
