Mott flail mower
/ Mott flail mower #1
CattleM2
John Deere 5065e
I recently purchased an old Mott flail mower, model M255 according to the tag. The guy I bought it from didn’t know much about it. I replaced the drive belt and greased it but noticed a small round opening on the drive shaft cover between the gear box and the belt pulley. It’s obviously a machined opening, I’m just not sure it’s a vent hole or an access opening that I need to fabricate a cover for the opening. It appears to have some grease inside it. Any suggestions appreciated. Thanks
/ Mott flail mower
Also where is a good place to buy replacement parts like bearings for the Mott flail mowers? I haven’t had much luck just searching online yet.
/ Mott flail mower #5
They got bought out by Alamo, so I’d speak to a dealer.
If you can get numbers off a ball or tapered roller bearing, usually those can be cross referenced easily.
/ Mott flail mower #6
/ Mott flail mower
Thanks
/ Mott flail mower
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
CASE 105C (A62177)
CASE 105C (A62177)
2022 Case CX220E Hydraulic Excavator (A61572)
2022 Case CX220E...
generator trailer (A61569)
generator trailer...
2019 CAT 259D (A60462)
