Clogged Radiators Hack
/ Clogged Radiators Hack #1
rockinbbar
Gold Member
South Texas
New Holland Powerstar 120, Powerstar 75, New Holland c245
Now and then I find myself away from my work pickup and air compressor, and need to clean the radiators when they get clogged, and things stop cooling, and start running hot...
I carry a bench brush with pretty stiff bristles in each tractor. It sweeps out the cab, and if needed, clears out your clogged radiators. :)
After a swift brushing.
It's the hot time of year when folks are using tractors on jobs that clog the radiators, so this may help a bit. At least until you can get to an air compressor.
/ Clogged Radiators Hack #2
In the case of slow-moving vehicles, having the radiator fan blow air forwards so as to reject getting clogged might work. Just need a fan with "backwards" blades. Cars, trucks, etc. move fast enough that airflow practically has to be from front to back, doesn't seem like that is so with tractor or mowers, etc.
/ Clogged Radiators Hack #3
That brush is a good idea, need a toolbox on mine to carry stuff. But don’t most tractors don’t have screens.. at least the newer ones? The screen on the LS plugs up in a hour brush hogging. But the screens easily cleans with a knock on the tire.
Some have screens and some don't.
This particular tractor is a Powerstar120, and it's only about a year and half old. No screens.
My other tractor, the same year model is a Powerstar75, and it has screens. Same basic engine, but different radiator system.
The fins are much bigger in my bigger tractor too. And vary ridged. The one's on the PS75 and much thinner and narrower.
/ Clogged Radiators Hack #5
I have 3 of those brushes from Harbor Freight. :love:
/ Clogged Radiators Hack #7
Years ago a few tractor brands had reverse flow fans, but that meant the incoming air had to be completely screened, plus the engine block kept the air flow much warmer. That has all been solved Reversing Fan for Heavy Duty Equipment - Flexxaire
/ Clogged Radiators Hack #8
We called that brush a "foxtail bench brush".
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
Hydraulic rail grinder (A61307)
Hydraulic rail...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2017 Ford Explorer 4x4 (A62679)
2017 Ford Explorer...
White 5100 12R Planter (A66285)
White 5100 12R...
2018 Case 650M OROPS Dozer (A62679)
2018 Case 650M...
