   / Harbor Freight Tools that don't suck #16,271
I have an amazon special version of THIS and it's way easier than the one you posted, I've used it and it works most of the time but the jack thing works every time to break a bead... the HFT tire spoons are fine though, they have some with round corners and ones with sharp corners depending on who they got them from, if you end up with the sharp corners round them off...
   / Harbor Freight Tools that don't suck #16,272
I have one of that type that has been used on a lot of large tractor tires. I've never tried it on car/pickup tires or ATV sized tires.I often use my loader bucket edge on those. I had to replace the valve stems on my SxS tires not long ago and I used the bucket to break the beads on those tires. Then I used irons to dismount one side of the tire so I could reach inside and install the valve stems, I was using metal bolt in angled ones.
   / Harbor Freight Tools that don't suck #16,273
Apparently I bought it just over a year ago when I had a leak in my rear tractor tire, the bead was rusted like heck to the wheel and nothing was working... That said I used it last weekend on some tires for my Explorer with 15" wheels, my bead breaker slide hammer was just sliding off, it wasn't the nicest thing to the aluminum wheels but not really that bad, I could have been more careful... used it last night to dismount the rear tire for my riding mower, 12" wheel... That thing and 3 spoons and I can tackle any tire I have...
   / Harbor Freight Tools that don't suck #16,274
You can SCORE a huge deal right now, this price has not been seen since 2020 !!! Even better than the last Black Friday sale!
   / Harbor Freight Tools that don't suck #16,275
That one is great and this is a great price. I've used one since they started selling it. Quality is the same as all the other brands. Maybe they're all made in the same factory.
But for some implements you will also need to add an offset hook, for clearance. See this recent post showing the difference.
Here's one source for the offset hook. A Speeco hook might be cheaper, I didn't check that.
Also note the slide-in pins for adjusting that hook. Recommended!
   / Harbor Freight Tools that don't suck #16,276
Yes, the SpeedCo :love: is about $15 cheaper with free shipping on Amazon. BoltOn costs more and you pay shipping.
BoltOn has a chain box for the HF QH, but the price is crazy high $65.
Then add the non-sealed lid for another $22.50.
The HF ammo can and two brackets will do the same thing for under $20 with a sealed lid. (y)
   / Harbor Freight Tools that don't suck #16,277
I bought a lumber rack for my Ford F-150. It works great and was 50% less than most other sources.
   / Harbor Freight Tools that don't suck #16,278
Anyone have any experience with the harbor freight brand oil based uv leak detector fluid you use with the hf Braun brand uv light?
   / Harbor Freight Tools that don't suck #16,279
Used an old used full-size pick up lumber rack to pretty extensively mod it to fit my old reg cab short box step side Tacoma. Only took it off cuz the upper bedsides we're getting rusty. They are so handy plus I could somewhat easily haul 16' boards with that tiny truck. Anyways sold truck long ago still have rack use it for storing stuff out side off the ground.
   / Harbor Freight Tools that don't suck #16,280
Apparently I bought it just over a year ago when I had a leak in my rear tractor tire, the bead was rusted like heck to the wheel and nothing was working... That said I used it last weekend on some tires for my Explorer with 15" wheels, my bead breaker slide hammer was just sliding off...
It looks like these are cheaper on Amazon. Hmm.... :)
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
WACKER NEUSON RTSC3 TRENCH COMPACTOR (A52709)
WACKER NEUSON...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
