How much ballast for a 40hp machine (TC40DA)
/ How much ballast for a 40hp machine (TC40DA)
I know you could make something cheaper. But you'd probably have half of this in it by the time you buy concrete, hardware, etc. Wouldn't you? This is a pretty easy way to add ballast and they'll deliver it to your door -- free. I filled mine with gravel and then hung some brake rotors on rods inserted into the vertical holes. Haven't weighed it but it did the trick. (This is just an example -- there are dozens of options online from different vendors.)
Yeah, but that's just the box. You still have to fill it with something. I have a frame that I built and mounted to my 3pt. Its a big rectangle with a vertical 2.5" sq tube (2" receiver) welded to it along with a couple of receivers on the bottom. I have forks that mount to it. My long term plan is to run a piece of 2" sq tube through the center of a barrel and have it stick out about 10" on the flat sized of the barrel. The plan is to leave the barrel flat on the ground so that (push come to shove) it can be rolled around. I'll pick it up with the forks when I want the weight. I'll weld some tabs to the sq tube to capture the forks, and then run a bolt through them to clamp it to the forks so it doesn't want to move around as much. In theory, that would let me put it further out on the forks as well, taking even more weight off the front axle. I'm not convinced the clamps will hold it out there, but I'm also not apposed to drilling a hole through each fork and pinning the weight in place.
If I can't get that built in the near future, I may pick up some more RR ties and just pick those up with the rear forks. I can get RR ties for under $20, and I need to get 8-10 of them for some other projects anyway.
Sounds like a plan. You have a good understanding of 3 point ballast vs loaded tires, which occasionally gets argued here on TBN.
I personally like having the full (75%) loaded tires, as I need all the weight I can get for snow plowing. I am considering adding 600lbs of iron to the rims (total) if I can ever get over the cost!
I'd strongly recommend tire chains. I've already found that the 1710 with 2wd and chains can push a lot more snow than the TC40 with 4wd and no chains. Having said that, I too like the way loaded tires behave with regards to traction. For where I'm at, what I have, and what I'm doing, traction isn't a huge issue.
/ How much ballast for a 40hp machine (TC40DA) #13
I have chains, but my customer base would not tolerate the chain marks on pavement. A big selling point for me is UHMW Polyethylene plow edges and no chains.
Worst case scenario (that I haven't encountered yet in 15 years) I can chain up and get the job done.
Unfortunately (or maybe fortunately) those are the customers who are willing to pay a premium to get the work done exactly the way they want it.
/ How much ballast for a 40hp machine (TC40DA) #15
Well sounds like you've got a plan!
Personally, I wouldn't want to push the weight FARTHER back for leverage. I think keeping the ballast as close as possible makes the whole tractor more stable and less tippy. Certainly wouldn't want it rolling back or moving either so your idea about pinning it or keeping it from moving makes a lot of sense. Never thought about RR ties, but again, wouldn't want all that length rocking side-to-side when you're looking for stability. It would certainly help keep the rear end on the ground but mine tends to tip sideways when turning with a big load up front.
Picking the ballast up with forks is a neat idea. Pics would be appreciated when you get it together!
/ How much ballast for a 40hp machine (TC40DA) #16
That's why I'm bumping this up on the priority list. I'm basically putting over 5k on the front axle which is a no-no. So far, I've only moved 9 boxes about 100ft each, this practice needs to stop.
If I load the rear tires, it won't be with 55gal in each tire. I don't want a machine that weighs well over 5k empty. Fluid in the tires gains me traction, but it doesn't get weight off the front axle. I'll start with a 55gal drum full of cement and see how things go. If it seems like I need more, I'll probably try to find a way to add more weight to the rear hitch so long as its not decreasing my loader's lift capacity. The more I can add back there, the more weight I take off the front axle, and the easier it is on the drivetrain.
If you have a bushog put it on semi permanent. Theres 600#+ and leverage. Add some weight on top of deck when you need it. Weight on the 3ph has no effect on lift capacity of the loader -- just gives stability and eases loading on front end components.
If I use RR ties, I'll likely drill a 1/2" hole though them and drive a piece of rebar through it, and then wrap a cheap strap around it to keep them all together. I have a couple pieces of ties left over from other projects. I'd probably lag them to the bottom like a runner so I could slide the forks under them.
If I'm using the loader, I'm not generally moving very fast. My understanding is that the loader weighs around 1100 lbs with no attachment. Forks plus frame is another 300 lbs. Combined, they apply more leverage from the rear axle than I'd ever be able to create with forks mounted to the 3pt. Now, if I hooked up my 6' bush hog, that might be a different story... :)
I had thought about that. Problem is that its currently behind all of my firewood (Ooops! Poor planning on my end), and I think mine sticks out further than most. It would make it pretty difficult to navigate around where I'm currently trying to work.
/ How much ballast for a 40hp machine (TC40DA) #19
Load the rear tires. Idk how people drive machines that have loaders and no weight on the rear.
Also 3pt balist is cheap but it sucks unless you never use any other 3pt attachment. I built one years ago and never use it as I always have something else on the 3pt.
/ How much ballast for a 40hp machine (TC40DA) #20
When I built my ballast box (a metal 55 gallon barrel) I put 2 3" PVC Pipes capped on one end with glue and the other the caps (rain caps) on top are lose. I use that as a place to store shovels and other tools as needed when using it. I left a little at the top for a length of chain.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
John Deere 1025R (A53317)
John Deere 1025R...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2015 Ford F-150 Pickup Truck, (A60352)
2015 Ford F-150...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
