Shell Rotella HD for Kioti DK6010SE?
   / Shell Rotella HD for Kioti DK6010SE? #1
future_vision
Gold Member
New England
DK6010SE HSA
I've been using the Rotella T6 for my engine oil in my Kioti DK6010HSE. I'm at my 400hrs and need to replace all the hydraulic fluid now. The manual recommends the following
Daedong: UTF55 or equivalent fluid oil
Equivalent options include:
Shell: Donax-TD
ExxonMobil: Mobilfluid 424 or Exxon Hydraul 560
BP: Tractran UTH
Would the Shell Rotella HD be a viable replacement for these?
   / Shell Rotella HD for Kioti DK6010SE? #2
I wouldnt think so, as the rotella is an engine oil. Im not positive, but i would assume as an engine oil its going to have different additives from a true hydraulic oil. Also viscosity issues. Ive been using Donax myself for hydraulic oils.
But im no expert. I guess you could ask your dealership mechanic?
I did find this advertisement from rotella, which seems to say it may work just fine. But i always followed the mfg required fluids while mine was under warranty, than just kept using it after warranty.
The Rotella HD is hydraulic fluid. It was previously called Donax TD. That alone mostly answers my question since that is the name the manual references. I just wasn't sure if it just a rebrand or if something has changed with the formulation.
   / Shell Rotella HD for Kioti DK6010SE? #4
Donax-TD is still sold, i just purchased 10 gallons of it.
Edit… i goofed up, its now called spirax s4
But says donax on can.
   / Shell Rotella HD for Kioti DK6010SE? #5
   / Shell Rotella HD for Kioti DK6010SE? #6
I have two Kubotas both gear drive and live in northern VT with a cold climate and use both tractors all winter. The L3010 I bought new in 2001 and use Rotella HD in it. The M5640 I bought used in 2017 and also use Rotella HD in it. Again they are gear drive not hydrostatic. No problems for me using Rotella HD in the transmission/hydraulic systems.
gg
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51243)
2024 AGT...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2011 Cadillac SRX LUXURY (A50324)
2011 Cadillac SRX...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
