I just bought an Echo 2511t clone for $99. What was I thinking?
   / I just bought an Echo 2511t clone for $99. What was I thinking? #141
It's a hollow box. How much 'muffling' can it do?
Guess you dont have a clone 2511 yet either.
It is HOLLOW with a small pipe. So how much does it do? :ROFLMAO:
Lot better then that oem stuffed up pos muffler they put on to hold them back.
My good ole stihl's and husky's were hollow too. 🍻 ;)
   / I just bought an Echo 2511t clone for $99. What was I thinking? #142
I expect an aftermarket pipe to offer performance. I wear mufflers
   / I just bought an Echo 2511t clone for $99. What was I thinking? #143
Call it what it is, a hollow exhaust box. No muffling going on there.
Nope, don't have one......yet. Maybe the OEM muffler can be 'cleaned' out?
.......and save $50
   / I just bought an Echo 2511t clone for $99. What was I thinking? #144
I bought the Egan, which is literally just a pipe. Also got the OEM mount for the air filter to secure it better.
Should be able to get it set up next Tuesday
   / I just bought an Echo 2511t clone for $99. What was I thinking? #145
.......and save $50
Sold as a muffler so calling it what it is sold as.
If dont like it just think it in your own mind. ;) :ROFLMAO:
The crap inside OEM. Least it isnt a cat muffler like some do.
Friend added extra exit to help too.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #146
Wait a min is your air filter wrong side on your clone then? That part where air filter goes is 2 different sizes.
OEM is big with big filter.
CLONE comes with small and should have small filter.
Clone carbs smaller too.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #147
My oem 2511 muffler isnt worth my time to gut like shown above.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #148
I showed measurements of both in my thread on junk saws.
I'm going to try timed cuts and compare everything I have on hand. I might even throw the stock stuffed up muffler in for laughs.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #149
The reading I've done said the clone inlet, was smaller than OEM, and the filter was OEM sized, causing the filter to fit very loose. Guys we're doing all sorts of shade tree fixes. Some bought the OEM inlet and it was a perfect fix.
Lots of videos of poor fitting filters due to incompatible sized inlet vs filter.
I'll have the saw in hand Tuesday and I'll know for sure... But I had not seen a single review that said the included filter fit the clone inlet.
I did see a lot of people buying the OEM inlet though
   / I just bought an Echo 2511t clone for $99. What was I thinking? #150
That was only when the mold was broke. The clone companies threw on oem sized which was wrong size.
I have not yet heard of wrong size filter on a Joncutter G2511 to date.
Plus the mold as since been fixed for the clone air filters.
Yours should be small and small.
But since you bought oem size you can now run the bigger oem size filter.
I grease both oem and clones. Big small both shown. Just hadnt greased oem then but was getting ready to.
Because most of us do not do BOOBtube BS. So much wrong info there.
All that info is in my group back when going on. If not there ask before buying.
2016 JEEP Cherokee SUV (A55758)
2016 JEEP Cherokee...
Exmark Lazer Z 96" Wing Zeroturn (RUNS) (A50775)
Exmark Lazer Z 96"...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
New 4-12-16.5 Forerunner Skidloader Tires & Rims (A50775)
New 4-12-16.5...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
2019 Ford F-450 12ft Utility Flatbed Service Truck (A55788)
2019 Ford F-450...
