Anyone have a MechMaxx 3-pt stump grinder?
   / Anyone have a MechMaxx 3-pt stump grinder? #221
I have a tractor mechanic coming over to help out. He has worked at Deere and Mahindra. I will share your advice with him.
If he cannot get it attached, my options are limited.
It only has to go on once so that is the bright side.
I cannot see a good reason for the pinch collar to be made that way. BTW, Tech support have not suggested opening up the gap. I suppose they figure if I crack it then the blame is on me.
It sure is puzzling that the tractor side of the shaft will not fit on the grinder shaft but fits on the tractor PTO shaft. Sure seems to point to a buggered spline shaft on the grinder.
I spent more time filing on the grinder shaft splines this morning with no success.
   / Anyone have a MechMaxx 3-pt stump grinder? #222
You guys were correct. Once we got the split hub pried open a bit more, the slip clutch side of the PTO slipped on.
I was just too much of a wuss.
Hopefully get a chance to try it out tomorrow
Appreciate the great advice fellows!
BTW the tractor mechanic who came over did not believe the low price. He figured it was about $2500. He told me I stole it at $1400
   / Anyone have a MechMaxx 3-pt stump grinder? #223
Spent some time today setting up the slip clutch. Not easy to measure to .01” so I proved my incompetence again.
Looked close enough, so went and ground two stumps for my neighbor. No smoking clutch plates so must be close enough.
The darn thing works really well.
Happy with my purchase.
Yeah the slip clutch seems to be set on the high-torque side to begin with.
One note of caution, Don. I had similar thinking to you, couldn't measure anything easily, figured why not try it first. Well, I did stall my tractor one time with a big cut into a hard stump. Not cool, as the whole point of the slip clutch is to prevent that and any damage to the tractors driveline or engine. So before I mount it up and use it again, I will have to loosen up the clutch and then work my way back up in torque to learn where it slips at.
   / Anyone have a MechMaxx 3-pt stump grinder? #225
Just an update.
Got a text from MechMaxx and they decided the spline shaft on the grinder was out of spec. Told them a tractor mechanic got it on for me and it only cost me $40. Told them not to send the replacement
Did not ask for the $40 for two reasons…they tried to make it right and it was an insignificant amount of money.
Deezler, I cannot figure out how to accurately measure 1.2x” from the plate to the top of the spring on the slip clutch. Decided it was easier to make up something that sits on top of the bolt and then reference off the top on the bolt that protrudes past the nut. A nut larger than the bolt works as the “spacer”and file or grind one side. Started with the bolt flush with this “spacer”. At least all the springs will be set the same that way. I went with a setting close to the 20-25 HP range to be safe…I have 32 PTO HP. If I find I need to increase the spring tension, I can eyeball having the bolt another .010 past the nut
Do any stump grinding yet?
I have a stand of around 10 trees in the 8 to 12” diameter range that i want to take out soon…. Do i laboriously dig all the stumps out with my backhoe, or just saw them down and grind the stumps …? Existential quandaries, now that i have tools of all kinds.
   / Anyone have a MechMaxx 3-pt stump grinder? #227
Sub 12" stumps could be ground in just a few minutes each. As long as there is no issue with the remaining tree below 4 inches or so, I would just grind them.
Backhoes are great when the whole stump has to come out, but then you have a hole to fill, and a stump to get rid of.
   / Anyone have a MechMaxx 3-pt stump grinder? #228
Did two. 8” and 12”. Took about an hour but expect that will improve with experience
Yeah well said, pretty much my experience and thinking also.
I think 3 of 10 trees need the stumps removed so i can lower the grade, then ill just grind the rest.
   / Anyone have a MechMaxx 3-pt stump grinder? #230
Perfect! Nothing wrong with playing with all of the toys!
Maybe do one Kenny Rogers style.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2017 Ditch Witch FX50 (A55973)
2017 Ditch Witch...
NEW Fork Extensions (A59000)
NEW Fork...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2018 Chevrolet Equinox SUV (A56859)
2018 Chevrolet...
