bad oil pump on a 2025 Subaru
/ bad oil pump on a 2025 Subaru #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
Hi folks,
We bought our first new car in 40 years. At 9000 miles, check engine lights came on while on the road. Lucky for us there was a Subaru dealer nearby. They couldn't look at it until the next day. After 2-1/2 hours, they said it was all fine now. Drove 200 miles back home. The next morning the code and check engine lights came back on and would die if at a stop. Our local dealer couldn't get it in for 3 days and it sat in our garage. Dealer said it would be fine to drive it in to the dealer.
After two days, they said it needs a new oil pump, showed zero pressure at idle! They have a pump on order and should changed out in a week
They claim the oil was clean, free of metal flakes, so there can be no damage to the engine. I'm a mechanical engineer and I'm not so convinced...
anybody have an opinion on this?
/ bad oil pump on a 2025 Subaru #2
I think you are been taken for a ride - watch out...
Zero pressure should mean no oil flow at idle!
/ bad oil pump on a 2025 Subaru #3
Hi folks,
Lemon law, perhaps?
/ bad oil pump on a 2025 Subaru #4
Lemon law, perhaps?
Lemon law pretty much covers problems that can't be fixed or are excessive. Warranty covers defects such as a bad part.
/ bad oil pump on a 2025 Subaru #5
Oil anaylsis. Ask the dealer for one, they probably just looked at the oil with an "eye-crometer". I doubt they still have the oil. I'd be worried too.
/ bad oil pump on a 2025 Subaru #6
Hi folks,
Most likely it wasn't true zero but extremely low. If it was the service writer is telling you this, I'd take it with a grain of salt as they can be less than accurate with transferring information from the tech.
If you are worried then have them send off an oil sample. Depending on what the true pressure is at idle and how quickly it increases, it's possible there is no damage. Modern synthetic oils can be pretty impressive with how well they protect.
Which engine do you have, the 2.4 turbo, 2.0 n/a, or 2.5 n/a?
/ bad oil pump on a 2025 Subaru #7
Hi folks,
Seems like something would be screwy if the oil pump had zero pressure at idle.
Granted, if it's not circulating oil, depending on what scored, would it have shavings in the oil pump??
Years ago, we had an engine shop rebuild a couple Mitsubishi diesels for us at work.
Got them back and sent them out into the field. Got a call from the customer saying one of them lost oil pressure and shut down after a couple hours.
Went out there and checked the unit. Changed the oil pressure gauge (analog), changed oil and oil filter and fired it up.
I sat there and watched it. It had great oil pressure then after it got to temperature, the oil pressure started dropping
Got it back to the shop, pulled the engine and oil pan.
The pick up tube for the oil pump had a hairline crack in it.
Cold, it sealed and had great oil pressure. As it warmed up, the crack expanded and oil pressure dropped.
Put the oil pan on, installed the engine, and sent the unit back to the engine shop for warranty repairs.
/ bad oil pump on a 2025 Subaru #8
That engine has probably sustained damage if the pump was not delivering oil. Maybe the engine was made for the 0-.005W modern thin oil so it is not as critical as would be in an older engine, but why even include an oil pump if not needed? Methinks this one is a ticking time bomb.
Sell to some sucker? 3
What's next, 3 out of 4 wheels is good enough? What, you expected two headlights?
/ bad oil pump on a 2025 Subaru #9
Way, way long time ago GM had tried the plastic covered timing chain sprocket. After 80k miles or so, the plastic would start to come apart on the cam sprocket. Replacement new timing sets were metal. Sometimes a piece of the plastic would block the bypass in the pump slightly open, so at idle the oil light would come on. I repaired enough of those engines I could do it in my sleep! I NEVER saw one that caused engine damage beyond a new timing set and cleaning. Engines are not highly stressed at idle. The engine very well may be just fine.
/ bad oil pump on a 2025 Subaru #10
The OP should ask to see the pump taken apart. If the pump has a bunch of wear, those particles were fed through the oil passages and that is very bad.
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
10222 (A56858)
10222 (A56858)
Giyi Gy-72Pro QA Mulcher (A60463)
Giyi Gy-72Pro QA...
Giyi KH72 QA 72" 4-in-1 Bucket (A60463)
Giyi KH72 QA 72"...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
Kubota B2301 (A53317)
