Help me decide, 3 trucks I need to pick 1 from.
   / Help me decide, 3 trucks I need to pick 1 from. #101
The wife and I were just talking about this yesterday. If a 2WD is all you need for towing on pavement she says a GM is about all one can buy off a lot, esp new. I don't know for sure but she says that if you look at a Dodge or Ford pickup in 2WD it will be a special order. If on hard top in that part of the country and you can stomach a GM that may be the hot setup.
I remember driving a 2WD Chevy 3/4T long box dually in the winter, in snow. That was one of the worst experiences in winter driving I can recall.
Buying a 2wd truck is just dumb. A 2wd truck can’t even go on moist grass. It’s not that much money upfront and 2wd knocks way more off your resale value than you saved upfront.
   / Help me decide, 3 trucks I need to pick 1 from. #102
Ok, so I'll give the thought process i heard from an old man, site business owner, and his old 7.3L. "Why on earth would I want a 4wd, less payload, less towing, worse milage, taller step, and if i ever get stuck, there is always a piece of equipment around to pull me out"
I dont necessarily agree, but if youre towing every day, hot shot, equipment transport, ect; he wasnt wrong.
   / Help me decide, 3 trucks I need to pick 1 from. #103
Having to get out and hook up a chain every time it’s even a little moist sucks. Having to load at the road when you could have went a few hundred feet closer sucks. Having to drag your truck a few feet by yourself and get out and correct the steering and repeat the process sucks. I’ve had 2wd trucks and trust me it sucks. If you’re going over the road I’d say it’s even worse. Have to pay even one wrecker bill would offset a lot of fuel savings. People are good at convincing themselves what they have is better. I seriously doubt many people that actually have owned a 4x4 truck are trading them in for 2wds.
   / Help me decide, 3 trucks I need to pick 1 from. #104
My Dad bought his first 4wd truck, a 1963 Ford 3/4 ton, brand spanking new and all the neighbors used to give him crap, using about the same arguments as you are putting forth. Till a January storm rolled around, with 3' of fresh snow. Guess who they called when they had to get out? That 1963 hi-boy plowed right through the snow drifts. And when chained up on all four it was pretty much unstoppable.
   / Help me decide, 3 trucks I need to pick 1 from. #105
I'm not saying that thought really fits everyone, but there is a reason to buy 2wd. Now, it also hurts resale. A clapped out, 2wd truck, worth almost nothing. A 4wd truck, even without an engine, still worth something as a mud truck.
Plenty of trucks will never leave at worst, a gravel surface.
Also, when I worked for the county, we had a 1500 GMC, 4.3L, reg cab, 2wd, street tires; and that thing would get stuck on wet grass....
I had gotten a new work truck when I worked there, 5.0 F150, reg cab, 4wd, with locking rear on a knob or switch. That thing could go through some bad stuff with just the e-locker, in 2wd. Save 4wd to get out of the worst of the worst
Had a 2wd, reg cab Dakota, 2.5L, that thing would Bury down in sand...
   / Help me decide, 3 trucks I need to pick 1 from. #106
Wow three new engines under warranty ? What happened to cause that ?
I am currently a Ford f150 owner with 10 speed automatic, very often hearing of folks having problems with them but so far mine has been flawless.
Currently in our household we have 1/2 tons, We factory ordered a heavy towing spec 2018 F150 and last year purchased my 2012 Pro-4X Titan. Both are fitted with E load spec. Michelins, Air Bag springs premium shocks, etc. & on the Titan their are some performance mods along with a big tranny cooler and other accessories.
Titan is used to primarily tow a 8000 lb. camper and F-150 a 12k flat bed. We have dump trailer and horse trailer plus other small trailers.
If we used the Flat bed and camper heavily, of course a HD pickup would be the better safer choice, but considering their overall use, I'm glad we have half tons.
I would consider spending some serious money on the old 2002 dually if it's bones are still good & solid, or go with a newer 7.3L Ford gasser over a diesel. Depending on miles per year, if high mileage, then only then would a diesel be cost effective.
In any case your needs require at least a 3/4 ton.
Personally, I was willing to spend $17k on an old $11k truck that is now more capable than most new trucks off the lot. (Aside from being a gas hog.)
New trucks will end up being mechanical totals, as they will be too expensive to repair.
   / Help me decide, 3 trucks I need to pick 1 from. #107
Im not a big fan of the idea of 10K behind a 150.....Can it do it.. yes. But the driving would be stressful and that alone would be enough for me to move up to a 250 or more. Even a 350 as those are 1500 or so more and have better resale. Getting a 23 or 24 as long as its full 5/100K warranty.. Really splitting hairs, They are basically the same truck with no significant differences. If paying cash.. Buy the cheaper one.. If financing,, Buy the one with the best rate. .. And financing it allows you to deduct the interest because of the BBB that was signed yesterday.
Credit unions may or may not give you a lower cost of ownership. I got a stupid low cash price on a 2018 Buick, so the Credit Union was the best way to finance. Investigate all options before signing.
   / Help me decide, 3 trucks I need to pick 1 from. #108
Here’s the Ford 7.3L “godzilla” gas torque curve everyone has wet dreams about lol
460 ft lbs? 🤷‍♂️
Today’s stock diesel makes more than twice that at lower RPM consuming less fuel.
Heck my smaller displacement Cummins 6.7L, de-rated cab & chassis makes like 800 ft lbs at less than 1/2 the rpm of the “godzilla”.
I mean no offense, but that’s actually pretty lame, IMO
   / Help me decide, 3 trucks I need to pick 1 from. #109
460 ft lbs? 🤷‍♂️
It’s almost the same torque the “legendary” 7.3 made.
   / Help me decide, 3 trucks I need to pick 1 from. #110
Very few people seek out the 7.3L powerstroke anymore. Its a huge engine with low output.
I look at the 7.3L gasser and I’m like, “meh-whats all the hype about”?
However, Cummins & Duramax are real popular at the track and the pulls.
New/Unused Spirit Electric Bicycle (A57453)
New/Unused Spirit...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
case 370 glass door never installed (A56436)
case 370 glass...
2010 CHEVY SILVERADO 3500 HD PICK UP TRUCK (A59575)
2010 CHEVY...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
2016 Ford F-150 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
