How big of a PHD?
   / How big of a PHD? #1
dnw64
SE Vermont, South Jersey
Kubota B3030 Cab
In sandy South Jersey soil, could my 23 PTO HP handle an 18" auger? I'm assuming that as long as I feed it slow it would be OK, but how slow is slow? Slower than digging by hand?
I will be planting approximately 50 trees, and really don't want to be wielding a shovel for all that, even if it is easy digging...
   / How big of a PHD? #2
You want a small tree transplanting auger not a standard straight auger.
Otherwise rent a small tracked excavator for one day and be done with it.
   / How big of a PHD? #5
The important part that you have not provided is the tree root ball dia. Root ball dia drives the hole dia and as Leonz says a tree auger ( tapered auger ) is best for planting trees, shrubs, etc. as it provides space for you to amend the soil and loosens immediate soil for good water uptake to provide plant greatest opportunity to thrive.
   / How big of a PHD? #6
An auger doesn’t take much power. This machine delivers 13 gpm or so which probably equals half your PTO power and it’s no issue at all.
   / How big of a PHD?
These are really small, and in plastic pots. Waiting on confirmation as to what is available, but it looks like probably 2 gallon which are 8-9" in diameter. It seems conventional wisdom is twice the width so that's why I was thinking 18".
I also have a backhoe for my tractor, which was my original plan, but I was originally thinking more mature trees (then I found the cost...).
   / How big of a PHD? #8
I often dig 12" holes for our fruit trees when planting them. I go down and if I want a slightly larger diameter hole I ease forward and backward a few inches. This wallows out the hole achieving the softening up the soil for the new plant/tree.
   / How big of a PHD? #9
Theres a saying that goes for a $20 tree you want to dig a $40 hole. This means the better the hole you put the tree in the more likely it is to survive.
For 9in pots I would be tempted to use a 12in auger and dig way deeper than needed. Then widen the hole with a shovel and put the spoils in the hole. You may want to add some organic matter to sandy soil to help keep the moisture in a new tree.
Trees really dont like to grow out though machine groomed sides of the hole.
In 2020 I planted 50 12-16in norway spruce in nasty clay. Started the job with a mini ex. Finished each hole by hand and added organics. Watered in the dry time of the summer each week and there 6' tall now. So a $1.25 tree is now about a $250 tree in 5yrs.
   / How big of a PHD?
Good concept. Thanks!
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
4 - JACK STANDS (A55745)
4 - JACK STANDS...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
JOB BOX W/ 100K X 20' NYLON SLINGS (A54757)
JOB BOX W/ 100K X...
2019 VOLVO EC220EL EXCAVATOR (A52706)
2019 VOLVO EC220EL...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
