Need advice on a machine to manage timberland
   / Need advice on a machine to manage timberland #11
Hello all, I am new to this forum. I manage 4000 acres of timberland in middle Georgia for my family. We have miles of dirt roads that need attention and I need advice on the most versatile piece of machinery to do the forest tasks we have at hand. The machine needs to be able to do road maintenance and create firebreaks for prescribed burns. The third party contractors that we hire use primarily small bulldozers to create fire breaks and replant seedlings. My past experience is primarily with ag tractors so a bulldozer would be a steep learning curve for me. The other problem with a small bulldozer is that it would require an expensive upgrade for a capable trailer and truck to move the dozer for maintenance and repair. I am retired so I have plenty of time. We can hire a bulldozer to do road repairs but that can quickly become cost prohibitive hence my questions here. I have looked at the New Holland Woods Boss but they are $80,000 new and used ones have been beat to hell and back by right of way companies. The dozer could work roads and pull implements to create fire breaks but they are also expensive, ($70-$80K) and would require the truck and trailer upgrades. Are used dozers a good option? Ideas on where to look?
Thanks in advance for your help and insight.
The most dangerous machine in the woods is a farm tractor. Timberland, 4000 acres? Get a cat with a drum, six way blade, and removable brush rake. quit trying to talk yourself out of one.
   / Need advice on a machine to manage timberland #12
With 4,000+ acres You will definitely need more equipment than just a big dozer !
Probably better off putting the work out on bids first to see what kind of bids you actually get and what kind of equipment they intend to use.
   / Need advice on a machine to manage timberland #13
We really don't know the level of steroids needed for the job that needs to be done. t=The OP needs to update us. with words and pictures.
   / Need advice on a machine to manage timberland #14
Airbuscuit,
You beat me to it. The OP appears to have lost interest or is lost in that 4000+ acres of timberland. Just being snarky BUT the participants need more input otherwise we are just flappin our gums.
   / Need advice on a machine to manage timberland #15
4000 acres requires equipment that costs BUCKS. You will not get away cheap. Hiring it out will be even more expensive.
My suggestion is to buy the biggest thing you can afford in several groupings. One would be a regular tractor with a bucket for normal maintenance. Secondly would be a "skidder" which is a tree machine with a blade and is heavy duty and can plow timber roads in the woods on sides of hills. Third would be a flat blade excavator. You will spend a pile of money upfront for this stuff. 4000 acres is no joke to maintain.
   / Need advice on a machine to manage timberland #16
In my opinion and limited timber experience, you need several pieces of equipment.
1) a tractor, to mow and maintain existing roads with several implements and a loader
2) a dozer to create firebreaks. Large enough to push down trees by the root ball. Install a cage around the operators station to attempt to prevent limbs from entering. Also some attachments for breaking up the undergrowth
3) skid steer with grapple to deal with moving brush piles. A forestry mulcher with this would be very helpful in keeping cleanup beyond the ability of a tractor and brush cutter.
   / Need advice on a machine to manage timberland #17
If I could win the lottery I would have a mid sized dozer with a backhoe. We have forest land to maintain and most of it is quite steep. A winch would also be nice but I think the backhoe would eliminate the addition of a winch - I've never seen a crawler setup with both.
   / Need advice on a machine to manage timberland #18
I agree with hslogger about the dozer with a 6 way blade. Roads need a crown to stay in any good shape. With the dozer you might need a forestry disk for firebreaks. Or...maybe not...the land I used to manage I used the services of the South Carolina Forestry Commission and their dozers. They can cut firebreaks at cost. Once done firebreaks are easy to maintain in the future. A removable rake up front would be needed. Loggers do not have the equipment to fix the roads nor the firebreaks. They tear everything up.
Here's a good start to get a plan:
  • Good Post
Reactions: M59
   / Need advice on a machine to manage timberland #19
Redbug's guidance is the most informed to date.
   / Need advice on a machine to manage timberland #20
The OP posted once and left. We don't know a lot about his specifics, and we don't know his budget. Maybe he's taken another job to be able to afford all this.
Towable Diesel Generator (A59228)
Towable Diesel...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56436)
2006 Tusk 500...
SUV (A59231)
SUV (A59231)
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
