Need advice on a machine to manage timberland
   / Need advice on a machine to manage timberland
A few questions - In your neck of the woods do they have many "off lease" tractors for sale? I've read a lot about them, but mainly in the wheat field area up north.
And about your bridges - bridges that are low enough to get wet in a flood gather flotsam and jetsam and act as a DAM. I had one on my land in Vermont. You need to build a simple bridge that is strong enough to be a DAM bridge or to swing away in high water. Attached such that you can readily pull it back with your 60 HP tractor when the water goes down.
No use fighting mother nature. She's a mother.
The crew that built the bridges had to make them robust enough for 60,000 pound log trucks so we are happy with them so far.
   / Need advice on a machine to manage timberland #44
Definitely a multiple machine requirement.
I'd go with your initial thought. I have a much smaller loblolly plantation. My 55HP machine can go between the rows. We hire out the thinning.
I'd budget for a future bigger machine to keep your breaks maintained. You can hire out or rent for now. With as many acres as you have, the smaller machine will be going all of the time. As retirees, we have to be careful about over work, too.
   / Need advice on a machine to manage timberland #45
Thanks. See my comment below about the bridge that was damaged by the flood!
If it is the bridge you showed in the photo then you definitely need a narrow piece of equipment. If your pulling a 8' tandem disc then a 50-60 hp machine is the right size. I would go with the largest disc you can fit between the uprights on the bridge.
If it were me I would get a 15' batwing mower, 90hp tractor and a box blade and skip the disc. The box blade will handle the road maintenance, the batwing mower folds nice and small for the bridge, and 90hp lets you work quick enough that you can fit the vegetation management in between rain storms if you have a wet year. I like to plan everything around wet years, and use the dry years to catch up on the "want to do projects". Keep us posted on what you end up doing!
   / Need advice on a machine to manage timberland #46
I know two different men who thought bulldozers were fantastic machines for clearing brush off farms until a piece of brush came through the operator's station putting each one of them in the hospital.
Wood dozers always have cages.
The more I read these comments the more I lean into hiring this work out. Watching the skilled dozer guy work the roads a few years ago was impressive. $50K equals about 333 hours of skilled dozer work. Probably the best way to go. You guys are a wealth of knowledge and I really appreciate your suggestions.
   / Need advice on a machine to manage timberland #48
I'd buy that grader for the road work!
   / Need advice on a machine to manage timberland #49
An interesting conclusion on your part and one of the benefits of this community.
Another way to look at your problem is. If you were to take the $50K or $100K and invest it and realize an average return of 10% then you could peel off 10% long term gain each year and pay the tax on gain ( max of 23.8% at highest bracket and much lower in lower tax brackets) and use that to fund the annual maintenance rather than buying equipment ( sunk cost at initial purchase ). The risk you face with investing is sequence of returns. ie: The market goes against you and at same time you take money out of the investment bucket so less money in bucket to grow for next gain.
When I buy equipment, I buy when a near term project ( within next 6 months) will pay off 50% or more of the aquisition cost and the equipment will fully pay for itself ( purchase cost, fuel, and maintenance cost ) within 3 years time. After 3 years the cost become maintenance and fuel.
I have not included my time cost as being retired the time cost is either equal to zero or equal to hired local contractor which you state to be $150/ hour.
   / Need advice on a machine to manage timberland #50
Well, the problem with that approach is like taking a cruise. You walk away with nothing tangible to show for it other than the memory. Go shop around for used tractors, individuals if paying cash or dealer if needing to finance. You can surely find a good condition, used tractor within that budget. You should be able to find something like a nice used Kioti RX7320 with a cab (75hp tractor) with 100 hours or less on it for the low $40's. Then as mentioned by some others, grab an 8' wide tandem disc, old and crusty is ok as long as its heavy built and in good condition. And lastly, grab a used angle blade or box blade. Those 3 things alone will give you an immense capability. You can put those same 300 hours on your equipment and when done have tangible equipment left that keeps you going for another 2000 hours while saving you ongoing rental/contractor costs for those hours. Unless of course you rather do something else with the time and then by all means hire it out. Either way, I'm sure the income on 4000 acres of trees will support and justify either direction.
Chisel Plow (A57454)
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
2022 Chevrolet Silverado Pickup Truck, VIN # 1GCUDEED6NZ533617 (A57453)
2022 Chevrolet...
2023 Kubota SVL 75-2 Skid Steer (A57453)
2023 Kubota SVL...
