PTO Shaft to Gearbox Bolts Keep Breaking!
/ PTO Shaft to Gearbox Bolts Keep Breaking! #141
Coming to this discussion late so I have not read the entire thread. Like dicktill said, can you get more pictures similar to post #89 showing the bolt fracture surfaces clearly? There are detail clues on those fracture surfaces that might help sort out what stresses are causing it. (lighting from a couple of different angles can reveal some subtleties on each of the fracture surfaces.) There appear to be differences in the way the Grade 5 bolts are failing and the way the Grade 8 bolts are failing (are these slightly different appearances consistent between all Gr5 and Gr8 failed bolts?), although the differences might not be that great. This also would not be surprising given the difference in strength between the two. There are some features on the fractures here that are suggestive of overload stresses (possible combination of bending, tension, and shear) and there are some features that are suggestive of bending fatigue. (post #36 from WI Hedgehog shows a great example of classic, "one-way" bending fatigue.) Once the fracture mode is known, can work backward from there on "how can the machine impose those loads/stresses on the broken parts?"
Initially I like IXLR8 suggestion in post #84 of using a bolt with an unthreaded body that goes all the way through the assembly, with a threaded section only long enough for assembly washers and the nut. (and, I like washers under both the head and the nut.)
/ PTO Shaft to Gearbox Bolts Keep Breaking! #142
1) Seems to me that if it was breaking from hitting something the bolt would be shearing in two spots. Could you be overtighening the bolt? 2) unrelated to your issue - - I think a grade 8 bolt is too strong to be used for a shear bolt.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #143
I have a 3.5 inch one in there now so we'll see on that part.
I tighten them until the head of the bolt and the nut make contact with the PTO shaft sides. So, no play but not tight at all.
I have wondered what would be better, tighten or leave a little loose?
He is not over tightening the bolt.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #144
What if the edges of the holes were VERY SLIGHTLY radiused? Not a whole lot, just enough so they wouldn't act like a bypassing shear. And why would there be a concern about having a bolt that was "too robust? There's a slip clutch on the PTO.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #145
Any thoughts on this one?
Mowing grass can pull more  steady power than just about anything. A couple things come to mind:
Use a longer bolt that moves the threaded portion away from the shear path.
Do you store the cutter outside? Even if the clutch is properly adjusted, rust can "stick" the plates together. I'd loosen the clutch tension some allowing it to slip just a little then re-tension. Hope this helps.
Have you made any witness marks on the slip clutch to confirm that it is slipping?
Maybe try loosening each tension bolt on the clutch an eighth of a turn and check it again for slippage and/or excess heat.
Yes, always do. thing is I haven't hit anything. Just mowing flat fields that are done on a regular basis.
Are you buying your Bolts from the same place? They may not be Grade 5 even though clearly marked on the head. There are a lot of counterfeit grade 5 bolts made in China on the market
and other than buying from a reliable vendor I don't know how to tell.
I have thought about this. Current bolts come from tractor supply.
Thanks for all of the suggestions and commentary. I haven't had a chance to look at things for a bit as I have been going sun-up to sundown with a break in the storms. Lots of mowing to do.
I hope to get back to this on the weekend and see if I can eliminate some of the items suggested.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #151
I'm wondering if it's a combination of variables:
  1. The hole in the collar or shaft is slightly oversized or wallowed
  2. The bolt isn't long enough (collar rests on threads)
  3. The bold isn't tight enough - allowing it to spin and degrade
  4. There is some unusual vibration at the gearbox
  5. There are demons at play
First I would use a longer bolt (so no threads in the collar), use a lock washer and tighten it tight. Maybe wrap the nut end with duct tape so you can retrieve it if it fails.
If that fails, see if a 14mm bolt will fit in there snugly.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #152
Using a 6** type Loctite and a grade 8 bolt would stop this problem. Heat would be needed to get it apart later.
Unless you unfortunately happen to use #620, which is strong up to 232C. This formulation is one of the strongest to start with, and gets stronger as it ages at mild heat. Youll be melting seals and blueing bearings to get this one off.
-- #638 would be a good choice. Highest strength but loses almost 50% by 100C.
Nothing new to report as I have been very busy in between storms mowing.
Idea: What do you guys think about using a "pin", something like you'd use on a toplink instead of a bolt to join the PTO shaft to the gearbox? This could give a uniform diameter all the way through. I know, just use a longer bolt, but I was wondering about why not a pin?
I haven't looked yet but I'm sure I could get a grade 5 or 8 pin. I'm not sure what the downside might be yet.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #154
I still think, use a longer bolt tightened down firmly, or a slightly larger (14mm) bolt that will be more snug. You don't want a pin spinning around in there wallowing out the holes.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #155
My guess is that a bolt is much cheaper than a "pin", and is a presumably known quantity as for shear value (grade 2/5/8 etc) vs the pin being whatever it is.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #156
Another vote for staying with bolts.
Wrap some duct tape around the pto shaft - bolt/nut assembly so it doesn’t fall out when it breaks
This should help with the big mystery of how it can break off only one side.
With duct tape wrapped a few times around everything, you will need to end up with 3 pieces for the pto shaft to loose drive
I am sure on cost a bolt is cheaper. If I did try a pin I'd make sure to order one that is a specific grade such as 5. Haven't looked yet.
I may try it just to see how it goes.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #158
Only advantage I can see is how trivial it is to put the lynch pin in to hold it.
That brings up another disadvantage - there will potentially be some shear -- probably not much but non-zero -- on the lynch pin holding the main pin, and who knows what those are made of. Of course you can use a bolt and nut there... with a washer... ok now we're way beyond the cost of just a bolt.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #159
Why do you seem to prefer a pin to a bolt?
2022 New Holland C327 Compact Track Loader (A61306)
2022 New Holland...
Kivel 48in. Forks and Frame Skid Steer Attachment (A59228)
Kivel 48in. Forks...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
Ford Pickup Truck Bed (A59230)
Ford Pickup Truck...
2014 GMC Savana 3500 Cargo Van (A59230)
2014 GMC Savana...
