NX4510HST Seat Replacement
/ NX4510HST Seat Replacement #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
If you ever price a new seat cushion for your Kioti tractor you will cringe. New Kioti cushions are over $600. I replaced my bottom cushion 2 years ago. It already has cracked in several places. This time around I said screw it and bought a folding seat with armrests from Vevor for $120 shipped. The mounting brackets are adjustable on the width and plenty of holes front to back. It also has armrests and a seatbelt. Plus the backrest is adjustable. The seat is adjustable and can be slid off the tracks to remove it. I can buy 5 of these seats for the replacement costs of one set of Kioti cushions.
/ NX4510HST Seat Replacement #2
In an unpublished video from back in 2018, I tried to shoehorn in a proper Sears air seat into my NX that is used in piles of different Case and JD et el tractors. I made new brackets to make the seat level and to sit as low as possible. Unfortunately, when I test fit the seat, it became obvious that I didn't have the headroom to be able to use the air suspension and so I put the stock seat back in. As I recall, the stock seat is weirdly built in that it's own suspension is difficult to remove from the seat itself. That said, if a guy can remove the seat pad, I suggest bringing it into an upholstery shop and have it recovered. A guy will need to remove the seat from the cab to do this by removing the four 12mm bolts and disconnecting the safety switch.
Last year, I replaced the worn-out seat in my Hough Payloader with this Vevor suspension seat that looks something like a much cheaper knock-off of a Grammer MSG65 suspension seat. From my experience, this same Vevor seat should (should, but I don't know for certain) be able to fit into an NX cab. That said, I suggest that a guy measure the stock seat height and compare it to the Vevor seat.
AGRIC AFMJ65 - 65" ROTARY TILLER (A64277)
AGRIC AFMJ65 - 65"...
2024 CATERPILLAR 304 EXCAVATOR (A65053)
2024 CATERPILLAR...
John Deere 757 ZTrak Zero Turn Mower (A66285)
John Deere 757...
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
16ft. Field Cultivator (A65640)
16ft. Field...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
