TYM wants to tip or roll over - need advise
   / TYM wants to tip or roll over - need advise #21
I have a HS 394 TYM with a quick attach pallet fork. I was moving a pallet with 33 bags at 50# per bag of mulch. The tractor kept tipping the rear wheel off the ground. I figured this to be about 1650#, is this too much front weight for this tractor? Do I need more weight on the rear?
Thanks for your help and advise
bob
Remember in your childhood, around me we called them seesaws. They should have taught you at a young age the effect of levers. I have nothing against filled tires as long as it is a noncorrosive and mon lethal substance in your tires. But weigh on the rear hanging back approximately 3’ is a much more effective counterweight for your loader.
   / TYM wants to tip or roll over - need advise #22
bob
You need to have less weight on the FEL.
   / TYM wants to tip or roll over - need advise #23
Also if it's a cast aluminum trans case......they can break more easily than people think.
Sorta related, my neighbor has a Kubota with a backhoe on it. He was working out a stump.
Cracked the cast aluminum case. Expensive part and expensive labor to replace.
He (and I) was shocked to see it was Alu and not iron.
   / TYM wants to tip or roll over - need advise #24
bob
That's an awfully tiny tractor to be lifting that much !! For heavy lifting I have an 1800 Oliver with fel.
   / TYM wants to tip or roll over - need advise #25
Good point. I do not have loaded tires? The only attachment I have for rear weight is a 6' brush hog. Is that enough?
yes that will work I like to use my 72" tiller - its heavier than m brush hog and I dont need to worry I'm going to hit something with it backing up or turning but yeah the brush hog will work.
   / TYM wants to tip or roll over - need advise #26
As Clover intimated, heavy lifts for a tractor can do more than meets the eye. Wheel bearings can be affected as well as steering assemblies and pumps along with gear teeth within the front 4wd housing.
It is also prudent to know the axle weight rating of your machine. Be aware of additional forces exerted when moving with a load that can cause the static rating of your axle to significantly be overwhelmed.
It is best to never use 4wd on a medium size compact with heavy lifting with the fel.
If you cannot successfully lift and move a heavy fel weight in 2wd, then you need more ballast that filled tires and/or additional rear weighting can provide.
Either that or provide yourself with 3 pt forks and lift heavier loads with the strongest part of the tractor.
   / TYM wants to tip or roll over - need advise #27
bob
Your loader lift max capacity appears to about 2,100 lb. I’m not an expert, but have been using my Kubota L3800 compact tractor to lift all sorts of things for 13 years (about 1,100 lbs loader lift capacity). I think it’s safe to say that you should have enough rear weight / ballast so that you can lift your loader’s capacity without causing your rear tires to lift off the ground. Otherwise, you can’t utilize all your capacity. Right ? With my yard box attached, I can fill my bucket totally full of dirt without lifting rear tires. Or with my 600 lb bushhog or 600 lb disc attached, I can lift machines that I know weigh 1,060 lbs. (I know I’m pushing the limit when it gets hard to steer),
If I couldn’t, I’d add weight to the rear,,, attaching a heavier implement, or sand bags on top of bushhog, or putting weights on yard box, etc.
   / TYM wants to tip or roll over - need advise #28
You bring up a good point.
Any heavy weight, within the bucket confines, such as material, will not produce the excess forces of a cantilevered heavy weight that straddles the bucket such as a tree stem.
The side to side forces, when moving such a load is what taxes the given weight capacity limits of the tractor.
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
2015 CASE SV280 SKID STEER (A60429)
2015 CASE SV280...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
