Buying a ZTR, what should I look for, or avoid?
/ Buying a ZTR, what should I look for, or avoid? #101
I might have agreed with that if I still lived in Michigan, but Texas in the summer with high humidity sucks all the fun out of the process.
Add to that the long sleeves, slacks and hat the dermatologist says I need to be wearing...
You need one of these:
The Stihl is a Ferris
Maybe so, but starting at $22K and not having the Ferris suspension puts it out of consideration.
Looks like it's built like a tank though. If I was running a yardwork company and didn't have to ride the thing myself...
/ Buying a ZTR, what should I look for, or avoid? #104
Don’t know what Stihl you’re looking at but the Rz 500 is sprung and tie rodded and starts around 8k. The 500 starts their commercial series.
Looks like the Ferris 3300.
There are Stihls that are 18k but that has a lot to do with engine size, larger deck width, larger tires and bigger pumps etc.
/ Buying a ZTR, what should I look for, or avoid? #105
3 years ago I got a Country Clipper XLT with the single lever steering. 50" cut. I really like it. I can cut all my grass with about 2 gallons of good gas (zero ethanol high test). It has a real comfortable seat with a mid height back. It will handle my hills up and down as long as I go straight up and straight down. I am too much of a chicken to try running along the hill and leaning over to the side. The Kawi engine is the only way I will go, having had quite a few Kohler engines and consider them nothing more than canoe anchors.
The flip up deck was also a selling point.
/ Buying a ZTR, what should I look for, or avoid? #106
Grasshopper here since 2009….3 actually. Newest one is the 900D beast. Always diesel for me. 2-725’s with 61” decks, one with vacuuming, 900 with 72” deck, grammar seat and tweels. I have had cub cadet mid mount, bad boy mid mounts…..no comparison to grasshopper efficiency and speed. I have lots of trees so a front mount is the best solution.
/ Buying a ZTR, what should I look for, or avoid? #107
I recently traded my bad boy diesel ztr in for a grasshopper diesel. Huge engine difference, but more comfort with the new one with uograded seat. The front deck makes it ride smoother too.
/ Buying a ZTR, what should I look for, or avoid? #108
Upgraded
/ Buying a ZTR, what should I look for, or avoid? #109
Ditto on pro model recommendations. BTW, King Ranch Ag on 59S sells Scag. Suggest: 1) when you get it home, do not mow immediately. Raise the deck and drive it around for 1 hour; Repeat for all operators to get familiar with the controls and 2) clean after every use with a leaf blower, especially the hydro motor cooling fins. Don't wash/power wash unless absolutely necessary. My Cheetah / Kawasaki has never been to the shop since I bought it new 10 years ago.
/ Buying a ZTR, what should I look for, or avoid? #110
This used to be my go to for gin mostly because of memories associated with it.. The original bottle on the left was 100 proof and the label as seen through the bottle from the back was the same as the front view. Now the proof has gone down and the appearance... yeah just not the same.
I never did quite find the prefect tonic water. I personally can't stand the stuff without gin, although the wife likes it.
None the less I like a good gin and tonic and there's a lot of new gins out there.
Good post... but wrong thread! :ROFLMAO:
/ Buying a ZTR, what should I look for, or avoid? #113
/ Buying a ZTR, what should I look for, or avoid? #115
I just got a used Kubota ZD326. I looked at new Scags, a used Gravely, and a ton of other stuff.
I am highly skeptical of the claim that a homeowner can't justify getting a diesel. If you have more than an acre or two, and you plan to be around for decades, a diesel seems like a good idea to me.
When I was shopping, I was told a gas engine is likely to die by 750 hours, and by 2,000, you should expect it to be scrap, while a diesel should go 3,000 before anything serious happens, and then it can be rebuilt. To me, 3,000 hours are probably 25 years.
Replacing a big gas engine by yourself costs $3,500+, so maybe $10,000+ over the course of 20 years, and it costs way more to have a mechanic do it. Unless your mechanic is a saint, expect to lose the use of your mower for a month or even three. What will you do about your grass while you wait? Diesel guys will still be mowing.
My understanding is that it's cheaper to rebuild a diesel than to replace a gas engine, and diesels are made to be rebuilt more than once. I'm no expert, so maybe I'm wrong, but this is what I have been told.
Gas engines have problems because of ethanol. I know about this firsthand. It is especially true where I live, with humid weather and all kinds of temperature fluctuations. Gas mowers burn more fuel and have to be refueled more often, which is really annoying. They are more complicated, so they have something diesel mowers never have: ignition problems.
Again, maybe I'm wrong, but I figured I could get at least 2,000 hours (call it 20 years) out of the used mower I just bought, with minimal repairs and easy maintenance. It may go a lot longer, and if it doesn't, I can have the engine rebuilt. I paid $5,500, and the best Home Depot gas mower, which is built to die after a few years of mowing 5 acres, costs around $3,000 more.
Additionally, Home Depot mowers are flimsy. My deck is 7 gauge. A Home Depot mower's deck is 10 gauge. That makes a difference if you want a mower that will last you 20 years. Home Depot and Cub Cadet expect you to be back in a few years to buy a new machine.
Speaking of new machines, I priced a Scag Turf Tiger II with a gas engine, and it was around $13,000 before tax. This is a really good mower. A Kubota would be somewhere around $18,000. Over 20 years, that's a difference of ~$300 per year. Seems worth it to me to get less refueling, no engine replacements, freedom from ethanol problems, and easier repairs and maintenance. And you can sell a 20-year-old Kubota. I'll bet there aren't many 2005 gas Scags on the market.
I was startled to learn how much money mowing your own lawn can save. Where I live, it could add up to over $100K in 20 years. That makes a commercial mower look like a gift.
  • Good Post
Reactions: JJT
/ Buying a ZTR, what should I look for, or avoid? #116
Most gas engines offered on commercial zero turns have a 2000 to 2500 hour expected life expectancy. (I expect that many hours out of my gas zero turn engines. I have a 35Hp Kawasaki and a 37HP Vangaurd EFI with oil guard))
It would take me 30+ years to hit that many hours on my zero turns.
A diesel upgrade on my 2013 Hustler Super Z was over $4000 dollars if I remember correctly.
It would take me several decades in fuel savings to save to the break even point for the extra thousands spent for a diesel.
For me diesel just wasn't worth that much extra cost IMO.
/ Buying a ZTR, what should I look for, or avoid? #117
What I have seen on the web are people saying that gas engines haven't lasted that long in practice. Perhaps they are wrong, or maybe they are not treating their engines as well as they should, though. Anyway, I spent $5,500 for a mower that probably has more than 2500 hours left before the first rebuild, and I won't have gas problems, frequent fuelings, or ignition issues, so I think it was a better choice than a gas anything.
I was mistaken about the $8,300 Home Depot Cub Cadet, which is a worse mower than I thought. The deck is 11 gauge, not 10. No wonder it weighs 500 pounds less than a Kubota. The Kubota's deck is 50% thicker.
I was also wrong when I said a Turf Tiger II could be had for around $13,000. The product I priced was a Tiger Cat II, which is Scag's cheapest commercial mower. It weighs about what the Cub Cadet does, and it's nothing like a ZD326. The price of a gas Turf Tiger II is around $17,000, so not far from a ZD1211.
The Tiger Cat II runs about half as long as a ZD326 on one fueling, and the same is true of the Home Depot mower.
I can see why a person with a small yard would like gas, though.
/ Buying a ZTR, what should I look for, or avoid? #118
I've run nothing but ethanol free gas in my zero turn since I've owned it.
The only time it's had ethanol gas in it was the couple gallons the dealer put in it to test it out and run it through the paces when I purchased it and they put it together.
I've had it for almost 8 years now. I put about 50 hrs a year on it, and i service it every spring just before I start mowing.
/ Buying a ZTR, what should I look for, or avoid? #119
In 2007 I bought a 2004 John Deere 54" Z-turn commercial mower. Still runs great, all I have done is changed oil/filter, greased it and sharpened/changed the blades. Still have the original belts on it. It is listed as weighing in at 1300lbs. Previous owner put a "comfort" seat on it, a suspension seat is now on my list. I expect it will last as long as I will. If I had to do it again, I would. It cost half of what a new mower would have cost.
/ Buying a ZTR, what should I look for, or avoid? #120
I see commercial mowers getting that many hours or more out of their gas engines all the time on Lawnsite.com
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
Kubota KX080-4 Mini Excavator (A65579)
Kubota KX080-4...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
