Buying a ZTR, what should I look for, or avoid?
   / Buying a ZTR, what should I look for, or avoid? #51
Without reading all the posts, and having my Hustler Fastrak SD for 13 mowing seasons now, mowing about 2-3 acres weekly on semi-rough terrain, I'd look for 4 things if I had to replace it:
1. A Kawasaki FX motor. It has been trouble free and is easy to maintain.
2. Hydrogear transaxles. Mine has 3100 transaxles and has been trouble free. The dealer services them every other year.
3. Some kind of suspension. My Fastrak has Hustler's flex forks, and I installed a suspension seat base. This helped a lot and was worth the $150 I spent on it at the time.
4. Quality product from a knowledgeable dealer. No off brands, no box stores. My dealer is a husband/wife/son operation and all work is performed by them. They don't sell garbage and the owner/son are first rate mechanics.
Good advice on all points.
If not suspension then at least a comfort sprung seat.
Mowing 5 acres is no small task on a weekly basis and with obstructions such as trees and such, lever movements are going to be numerous so only the best componentry should be had.
   / Buying a ZTR, what should I look for, or avoid? #52
... and with that bit of humor, I'm out to finish moving the the last of the 24 yards of mulch I had delivered. :rolleyes:
Mowing is actually the easy / fun part of the property care package. Weeding gardens and trimming shrubs is the part I hate, so I hire that out after the initial spring cleaning and mulch are done.
That’s a lotta mulch Winter.
I complain having to move 5 yds of the stuff.
   / Buying a ZTR, what should I look for, or avoid? #53
Honda is getting out of walk behinds.
They have had a cam issue that if I told you the ridiculous dealer remedy they purport, you’d wouldn’t want one either.
   / Buying a ZTR, what should I look for, or avoid? #54
Yeah, it's a big pile. But we have about 0.75 acres of manicured gardens, so that 24 yards is would be an impossibly-thin 0.25" thick top dressing, if spread uniformly. Thankfully, we have a lot of ground cover and shrubs that have reduced the amount of mulch we need each year.
I did 60 yards my first year here, digging out all of the prior owner's black-dyed mulch and replacing with natural bark mulch. Then 40 years each of several years after that, until shrubs and ground cover filled in. Then I had one massive year of 110 yards when I converted a 1/4 acre corner of the yard from lawn to garden. Thankfully that's all filled with mature evergreens now, which self mulch, and a lot of ground cover in front of that, so I really only clean out and mulch the front 10 - 20 feet of that garden now.
   / Buying a ZTR, what should I look for, or avoid? #55
In my original post I asserted that some companies (more like some models within companies) were putting too small of hydro units on their mowers.
However the hydros are rated for a max weight. Many companies will skimp on they hydro creating a mower that is to large for the hydro.
Toro Titan 60", 845 lbs.
Uses HydroGear 2800 that is rated at 1000 lbs max.
That leaves 155 lbs for the operator and 5 gallons of gas (30 lbs) so dont fill it up and weigh more than 125lbs.
So after reading @gengine comment I started doubting my post on the pump / motors being too light for mowers and perhaps I was wrong in my assumption of the hydro's being rated as a pair and the rating might be as a single side. In which case I disqualified some nice looking mowers such as the Toro Titan I mentioned in my first post.
I was a Husqvarna dealer for 12 years, just changed careers a year ago. Trans axles are used in lawn tractors. ZTRs use 2 pump/motor units, at around 1000# a piece, giving you nearly 2000#.
As for the OP, If you went for a Husky, I would say a minimum of a Z4xx series, it is a robust residential unit. If I were doing what you are, I would buy a Walker, hands down.
So I reached out to Hydro Gear for clearification if the weight rating for zero turn pump motor units are rated per unit. For example I used a Hydrogrear ZT3400 that shows a gross vehicle weight of up to 1600 lbs.
Is the 1600 lb weight rating on the ZT3400 for per transmission for 3200 lbs or a set of transmissions?
Their Response:
The 1600 lbs is the combined weight for the 2 units on a machine.
So in GEngine's example a 2 pump unit rated for 1000 lbs would give you 500 lbs per side.
I've never seen a ZTR with just one of those transmissions. Must be a unicycle ZTR. :ROFLMAO:
Yep, thats why the the pump / motor weight rating is as a pair.
Hope this helps folks.
   / Buying a ZTR, what should I look for, or avoid? #56
Toro Titan 60". 761lbs. Even if the ZT-2800 hydros are rated to 1000lbs as a pair, Toro sized the Titan for a hefty 240lb person. Seems well within reason and not undersized or underpowered for a residential mower. Some people could stand to lose a few pounds for the sake of the mower. Lol
   / Buying a ZTR, what should I look for, or avoid? #57
So this is where things get interesting. I linked in my original post to Toro Titan 6605.
Toro Titan 6605 60", 845 lbs.
You linked to Toro Titan 6604.
Toro Titan 6604 60", 761 lbs
The 6604 would be 1000-761=239 lbs (no fuel so 209 lbs with fuel 5 gal x 6 lbs per gallon) That is darned close given the average American male weigh's 199.8 lbs.
If you put a bagger on it then it will definately be over weight, with most that weight over the rear hydro units.
I would love to know what drives the differences in weight between models. This is why on the latest post I noted that it varies by model within the same company.
Toro defiantly has the largest variation in weight within a model family. I am not sure why.
   / Buying a ZTR, what should I look for, or avoid? #58
What I've learned about mowers is to start mowing around the house with a gas or electric push mower. Stop after one hour. That is the maximum size of your yard. From then on, mow your yard with whatever you want. All the rest is a field for the tractor/cutter to cut a couple of times a year.
Don't be a slave to your lawn.
:D
Bruce
Excellent advice. To me the max is 100 yds/meters out in a radius from the house/buildings. I like your time-based approach. Too many people out in rural areas seem to forget they don't have to keep their entire acreage in 'lawn'.
   / Buying a ZTR, what should I look for, or avoid? #59
I sort of agree also. I can cut an acre of land around my house and barn, in one hour with a 38” cut, hydrostatic lawn tractor. I’ve got no use for a push mower, but one hour is the limit for the time it takes to cut my own lawn. I’ve also got very little use for a gear lawn tractor but I do keep one of the same cut width and engine size for backup, or when the lawn is too thick to waste the extra horsepower on the hydro.
I’ve also taken on the added responsibility of my parents 4 acre lawn because my dad is no longer able to safety get on and off of his 54” zero turn. I just replaced his 5 year old “residential” Husqvarna, with a new z-454 commercial model. It take me two hours to cut that 4 acres with that and it uses about 2.5 gallons of gas to do it.
I’ve cut that (3) times this year so far and the novelty of the zero turn hasn’t worn off yet. I still look forward to doing it each week. Their neighbors on each side have struggled to get their lawns cut this year, each just starting on then in the last week. Their grass was 2-3 ft tall.
The one to the south only cut a wide “oval track” around their house, leaving the corners uncut. My mom asked me to cut the adjacent uncut corner section of that neighbor’s yard. The new z-454 didn’t do too bad on that. I raised the deck to the maximum cut hieght (4.5”), went slow, and went over it twice. It turned out ok.
Those zero turns are definitely efficient. I’m not crazy about the lawnmowin job, but a riding mower at least makes it bearable. A hydro transmission make it a little better, and a zero turn make it fun.
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
REDBALL 4R HOODED SPRAYER (A52708)
REDBALL 4R HOODED...
2011 Wanco WLTC4 Towable Light Tower (A56857)
2011 Wanco WLTC4...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 John Deere 1653 (A56436)
2018 John Deere...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
