Identify Manufacturer
/ Identify Manufacturer #1
Gampy
Pennsylvania
Ford 3930, John Deere 4100, Massey Harris Colt 21
I am hoping someone can help me identify a flail mower I acquired. I purchased a Ford 3930 back in the winter and the seller offered me a 7’ flail mower at a reasonable price. Now that mowing season is upon us I noticed that there appears to be a part missing at the end of the blade roller. I am guessing it is a Bearing Assembly Shaft. I pulled the covers off but can not find a brand name anywhere on the unit. Any ideas of the Manufacturer and model from the pictures so I can attempt finding parts? There are a few stamped numbers on the covers but all my searches came up empty. Thank you for any help.
/ Identify Manufacturer #3
Looks like an Alamo.
/ Identify Manufacturer #4
And welcome to TBN.
/ Identify Manufacturer #5
That is an alamo SHD series. I cannot tell if it is a SHD74, SHD88, or SHD96. Yours is an offset model, which probably means its a SHD88. I suspect that you have some rust issues on the rear under the rubber mat. Alamo did not put drain holes in front of the rear pipe and water collects there and rusts it out. I drilled a 1" hole there and behind the front pipe on both sides to let water out.
Below is a link to the:
Sales brochure.
Operators manual
Parts manual
Flailmaster has parts
ALAMO/MOTT Parts
Montage is another one.
Alamo/Mott Flail – Montage Enterprises
I have a center mount SHD88 with the course cut blades and really like it. It is the perfect fit between a finish mower and rotary cutter. It leaves a nice finish, not finish mower quality but good enough for me. On my lumpy and hilly fields the roller being right behind the blades makes it almost impossible to scalp.
Below is a photo showing the holes I drilled.
/ Identify Manufacturer #7
I believe those had a collar with set screws on the cutter shaft opposite of the pully. If I remember correctly the collar matched up to a oval shape in the inner race of the bearing. You had to spin the collar to lock it on the shaft and bearing then set screw it.
Sales brochure.
Operators manual
Parts manual
ALAMO/MOTT Parts
Thank you for the help with the identification of this unit. Great info and advice and really appreciate the link to the manuals and parts. I already have them printed out. Now that its not 100 degrees here in Pennsylvania I will tear the unit apart and see what needs replacing. Many thanks
In looking at the parts diagram that was provided by another member I believe you are 100% correct. My guess would be that the set screw worked its way loose resulted in the bearing spinning off. My hope is that I can get away with just replacing the bearing and not the entire assembly.
To the OP; I didn't participate but want to thank you for coming back and letting us know. Too often somebody joins, asks a question and never is heard from again.
I know the feeling. Just common courtesy in a world that has unfortunately, continually lost its values. I just recently joined because I had a specific problem regarding the flail mower. I have “crept” on this site for year, without being a member researching past posts and threads on several other tractor questions and have always been surprised that most of my questions were already answered by this community. Great site and a
Very knowledgeable group
Brute Pressure Washer (A65640)
Brute Pressure...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2022 EZ-GO ELITE...
2024 Ranger 1500 Extreme Duty North Star (A62679)
2024 Ranger 1500...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
