etpm
- Joined
- Jun 30, 2021
- Messages
- 2,385
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Several years ago I bought my Yanmar YM2310. My previous tractor purchases were a Case 580 CK and a Ford 9N. I had no experience with tractors made for rice paddy work. The seller told me that the tractor had not moved for 2 years and that the clutch was stuck. I got it started and drove it home with me pressing the clutch pedal down all the way home, which was about a two mile drive. The clutch started to slip when I was close to home. I determined that the clutch disc had broken loose from the flywheel or the pressure plate but was still sticking on the spline on the clutch input shaft and this caused the clutch to drag. After my son and I stepped on the clutch pedal countless times the clutch disc finally broke loose from the spline and the clutch started acting normally. There is a lever that is meant to be slipped over the clutch pedal when it is depressed to keep it in the depressed position when the tractor is parked for long periods of time and so avoid the whole clutch sticking business. Since the clutch was no longer sticking and I felt that it was being driven often enough I stopped using the lever that keeps the clutch pedal depressed. It turned out that I needed to use that lever more. After being parked a couple weeks the clutch stuck. I broke it loose by driving the tractor about 1/4 mile with me stepping on the clutch pedal. I then used the tractor for a few hours and everything worked great. I then parked the tractor for a few days and when I went to use it again the clutch worked properly. Then I parked it for about a week and the clutch ended up sticking badly. After trying for a few hours to get it to break loose I gave up and parked the tractor. I parked it with the lever in place holding the clutch pedal depressed. The tractor sat that way for a few weeks and then my son went to use it yesterday and it worked fine again. I think what is happening is that the clutch disc is sticking on the spline. It is sticking because it needs to be lubed but there is no way to lube the splined shaft without splitting the tractor. So if your Yanmar clutch is experiencing this sticking issue it would be wise to use that little lever that holds the clutch pedal down if you are gonna park the tractor for more than a week or so. And if anyone knows how to lube the splined shaft without splitting the tractor please lest me know.
Eric
Eric
