Is my problem solved?
   / Is my problem solved? #21
I have a hip that pops out of joint so that side will sit a 1/2" lower then the other hip. Never realized that was my issue until I had back pain for about 6 weeks and decided I better go to the doctor.
He had me stand straight and checked my hips. And pointed out that one side was lower than the other.
I've been dealing with it for years now and can immediately tell now if it popped out.
I've also figured put a similar move to get it to pop back in.
If it's being really stubborn, I can lay on the couch with that leg hanging off the couch. After a few rotations side to side with the leg, it will pop back in.
Yikes! I'm glad you know to fix it.
Different antihistamines target different pathways in the body. Zyrtec hits one. Allegra another. Both are OTC. Singulair (monteleukast) targets a third. For some folks taking more than one can help, but check with your doctor first...
All the best,
Peter
   / Is my problem solved? #22
I've always had problems with sinus/ear infections especially the past few years. Had a series of them in 2023 and lost much of my hearing in my right ear. Had several more in 2024. Took all kinds of antibiotics and steroids both of which caused other problems. And I've had several procedures on that ear to try to regain some hearing. Earlier this year my daughter convinced me to go to her chiropractor. She has had migraines since high school, about two a month for nearly twenty years of really bad ones. She was skeptical but a friend insisted that this guy could help her so she went to him. And since going to this guy she has not had a single migraine. So I started going to him even though I've always regarded them as witch doctors at best. Not a sinus infection this year so far instead of the usual four or five trips to the doctor.
BUT!!
My wife started having a rash on her arms about a year or so ago. Around the first of the year she finally went to a dermatologist to have it checked out. Not gonna go thru the whole story but she has developed an allergy caused by something contained in the COVID vaccine. Doctor said it had become very common. Said to never take another of that type vaccine. Anyway, when she started having these rashes I started changing our laundry detergent, fabric softener, etc.. Now everything we use is the Free and Clear type with no dyes, perfumes, or other additives.
I just realized this past week that my lack of sinus infections could be the result of the change in laundry supplies and not the chiropractor. Any idea?
RSKY
This only happens when people switch their laundry detergent from ItchyEyes-n-Sneeze to Free-n-Clear. You should of given up on that brand a long time agoooo. :ROFLMAO:
   / Is my problem solved? #23
Man, oaks were BAD this year! I have to start wearing a respirator when I mow or I'll be coughing for a couple hours afterwards.
I'm fine with white oaks, less tannins. Red oak is the worse.
The pollen is so fine, you would need the highest level of reading glasses to see it in the air.
Oak pollens are 40 µm in size, with an irregular outer layer (exine) and three tapered apertures (furrows). These pollens are tricolpate comprising of three grooves with verrucate (wart-like) or scabrate (isodiametric rough structure) on the exterior surface (1). Que a 1 is identified as the most potential allergen from the pollens of this oak species (6).
https://www.thermofisher.com/phadia/us/en/resources/allergen-encyclopedia/t7.html
And chances are, those with oak allergies have a sensitivity to ginkgo and grass species like timothy grass. :rolleyes:
   / Is my problem solved? #24
Timothy grass gets me along with oak pollen.
I moved to an oak forest with a cow pasture across the street with Timothy grass
If you have a powerful flashlight you can see the pollen after dark by shining it up in the air and looking across the beam.
The light will reflect off the pollen.
I discovered this accidently.
Now my wife will look outside and catch me playing light saber with the flashlight beam and the pollen while walking the pooch
   / Is my problem solved? #25
Flonase is a godsend for some of my friends…
   / Is my problem solved? #26
There's also PurpleAir air quality gizmos to keep track of your outdoor air quality. PurpleAir.com
But I'm sure that light sabers are much more fun.
All the best,
Peter
   / Is my problem solved? #27
All the best,
Peter
I can't help.it if my inner 12yo comes out
   / Is my problem solved? #28
BUT!!
RSKY
Never got the jab nor did I ever wear a face diaper either. Never got it ever.
   / Is my problem solved? #29
I got it at the very beginning. Picked it up from a temporary employee who went to Mardigras. I was sick for 3 days and it was identical to how the flu affected me.
   / Is my problem solved? #30
Mom was in skilled nursing and all those around got it… staff and patients… mom never got it and tested daily.
At work we pretty much avoided getting it until we all got it…
Christmas Party and almost no one signed up but hospital managers kept asking… almost everyone that went to Hospital Christmas party got it… no one had a severe case but 10 days mandatory home isolation…
If you wanted to keep your job declination not an option… we all had the first 2 Moderna at the time…
   / Is my problem solved? #31
I played hermit and so did my wife. Read too many negatives about the jab to get it and I was retired at the time so nothing mandatory about having it for work as I worked for myself anyway. Don't know if my employees got it, never asked.
   / Is my problem solved? #32
Got my nose swabbed more than once if I remember correctly. Was dealing with the early stages of colon cancer so I had toi wear the diaper at the hospital and get tested regularly. Still have the cancer issue today, just not colon cancer, that was surgically removed as in 14" of my poop chute. Now it's inoperable cancer in my liver but it's under control. Been dealing with it for 8 years now and I don't wish cancer on anyone, not even Haydude...lol I can see why so many people die from cancer as they are unablle to afford the drugs related to it.
My current oral chemo is 35 grand a bottle per month of which I pay 85 bucks.
No one can afford that stuff in reality and I'm thankful I have ultra high option BC/BS Federal Employees heathcare. My total medical bills pre insurance is well in the excess of a millon five.
Just insane amounts.
My youngest daughter's husband was one of the first in our area to get COVID. He ran a temp over 100F for 21 straight days. The only thing that would stay on his stomach was Coke from the local McDonalds. Water or Gatorade would go straight thru him. Drink it in the kitchen and have to run to the bathroom. We think he would have died if not for a nurse at our church (30+ years emergency room nurse) who gave my daughter step by step instructions for his care over the phone. And a gynecologist nurse practitioner who was the only one that would see him as a patient. Daughter would take him in to the clinic and she would start an IV and get fluids into his system. The nurse practitioner was one of the first in our area to get the disease and said she had immunity. That NP said that everyone she saw who had a severe case of the disease was low on vitamin D. So everybody in the extended family started taking supplements and none of us had as severe a case as David.
RSKY
   / Is my problem solved? #34
As someone with lung/respiratory issues I would suggest making a home-made Corsi-Rosenthal box. See u-tube or web-md for specifics.
Merv 13 rated filters and a cheap box fan and some duct tape.
I wear a mask when mowing and have tried to have SWMBO use less scented detergent and softeners on my clothes.
Good luck to all.
R
   / Is my problem solved? #35
Do you make that noise, too?
Ffffkrrrrshhzzzwooooom..woom..woooom..​
   / Is my problem solved? #38
RSKY
Wow, what an intense experience! I’m so glad your daughter had such knowledgeable people guiding her through it. It sounds like the combination of care, support, and those vitamin D supplements made a big difference.
My uncle also was one of the first in our area who caught Covid. We were frightened because he is also diabetic. It was a challenge to buy his meds. Fortunately, we found a way to buy Mounjaro online. But still, people with diabetes are supposed to be at higher risk. He spent almost four weeks in the hospital. The condition was bad, but luckily, he started getting better. I should say, those doctors and nurses who worked with Covid patients and who didn't actually know what consequences they might have faced, are real heroes for me.
My uncle also was one of the first in our area who caught Covid. We were frightened because he is also diabetic. It was a challenge to buy his meds. Fortunately, we found a way to get them. But still, people with diabetes are supposed to be at higher risk. He spent almost four weeks in the hospital. The condition was bad, but luckily, he started getting better. I should say, those doctors and nurses who worked with Covid patients and who didn't actually know what consequences they might have faced, are real heroes for me.
The nurse practitioner that helped my son-in-law so much said that he needed X-rays of his lungs but that if he went to the local hospital they would keep him and he wouldn't get out alive.
The ER nurse told her to give him Tylenol and Motrin at three hour intervals alternating the drugs. And if his temp didn't start down to cut the time until it did go down. Same thing that you do with an infant. Daughter was told by local doctors not to do that. She took the nurse's advice and it worked. She had called me that morning and said his temp was down to 101 and he was improving. Then four hours later called hysterical with it about 104. My wife called the nurse and she called our daughter.
Sometimes the nurses do know more than the doctors but the doctor that put himself in charge of the COVID patients at that hospital was/is an idiot.
RSKY
iDrive TDS-2010H...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A56438)
2010 Doyle 32ft...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
2001 BOBCAT 773 SKID STEER (A60429)
2001 BOBCAT 773...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
