Loader hoses
/ Loader hoses #21
Using that logic, every hose, belt and the tires should be replaced too because 'stuff happens'.
True, but with belts and tires you can see wear, aging, cracks and damage and replace proactively before they fail. Somewhat harder are the radtiator and fuel hoses, they like hyd lines can fail unexpectedly.
I keep lengths of fuel line, and could do a temporary fix on a radiator hose with a clamp and fitting.
/ Loader hoses #22
? You're mis-quoting Carl. He never said to replace anything. He suggested getting spares as cheaply as possible now, on the assumption they'll be needed someday, so that the OP isn't hunting for an expensive emergency solution when the time comes.
I also keep some spares, mostly things like mower belts and sheer bolts. Stuff only seems to break around here after the parts store has closed for the weekend.
/ Loader hoses #23
Thanks WinterDeere - yes, that was my main point, and while you could splice a pressure side Hyd line, I would not want to attempt - a radiator or fuel hose, sure as a temp fix.
/ Loader hoses #24
So curious, what protection does the sleeve provide? Is that for UV protection?
/ Loader hoses #25
I'm sure it does provide some UV protection, but I think the outer layers of most tractor hoses are already UV-stabilized materials like PVC.
I see them used in areas where rubbing or abrasion are likely, such as between the rockshafts on the rear, so figured they're for a little extra abrasion resistance.
/ Loader hoses #26
Sleeve provide lots of protection from abrasion and sun. Buy the sleeving on Amazon in 100 foot rolls. Every new hose gets a sleeve. Be sure to cut them too long, they shrink lengthwise. Fasten ends with zip ties.
/ Loader hoses #27
The outer layer on most hyd hoses is marginal at best on UV, some of the more expensive options are better, but I still see a lot of degradation on equipment that sits outside a lot. I now put them on any hose that is exposed to a lot of UV.
Secondary advantages are it helps diffuse a stream in the event of a hose bust, protects from abrasion, and can be used to control multiple hoses in one cover.
/ Loader hoses #28
I always hated using zip ties for the ends, switched over to metal crimp cramps a few years ago. Look much more professional and less likely to fail.
/ Loader hoses #29
I'm in the 'wait till they start deteriorating" camp. No use in replacing good parts.
Heck, even a brand new hose could blow in two weeks, life is full of surprises.
He doesn't advertise it but @kennyd can make hoses for you. High quality and reasonable prices. (Home - BoltOnHooks LLC)
/ Loader hoses #30
So buy new and leave it on the shelf? Still makes no sense to me...but we live in 'Merica and we can all make out own choices! Yeah!
/ Loader hoses #31
Thanks for the mention @dicktill
I don't advertise it because I don't have time for the 'what fitting is this' emails and phone calls, I get enough of that for the restrictors and gauges we sell! If you know what you need, in 1/4" or 3/8" hose size, I'd be happy to give anyone a quote.
You'd be amazed how many people send me fuzzy pictures of a connected hose asking me to ID the size and style for them...
/ Loader hoses #32
It makes sense when your time is worth something. The hours I get away from my desk between projects are seldom enough that a lost weekend is infinitely more important to me than the cost of a hose or belt sitting on the shelf. Everyone has to set their own priorities.
/ Loader hoses
I got my hose “kit” for my B7800 today. They look good and everyone is an exact match for length and fitting. $145.00 delivered for 8 hoses!
/ Loader hoses #34
Orezok - great deal - low cost too, where did you source from?
/ Loader hoses
I got all 12 hoses installed, new UDT2, filters and screen cleaning. Considering that I’m 78 and only do 30 to 40 hours a year, its the last time ill have to do it again.
/ Loader hoses #37
Well, I am in that school, too. Or I usually wait until they actually leak.
Both ozone and UV are not your hoses' friends. I remember getting some new hoses made for my hoe attachment years ago from DHH, and they failed in 5 years! Crappy rubber. Surplus Center hoses have been excellent.
That said, my tractor turned 20 this past spring, and Kioti sleeved all the FEL hoses in cloth sleeves. None have leaked or been replaced. Can't say the same for my aftermarket hoe, tho I sleeved what I replace, if I can. I almost always park in my shaded tractor-port.
I gave up on local hose shops years ago ($$$$).
/ Loader hoses #39
That old probability vs. impact debate, of risk analysis:
I don't know who Grace LaConte is, this is just the first image I pilfered off Google, but I used to have to fill out dozens of these for every government contract job.
/ Loader hoses #40
If a loader hose fails, it might kill you.
Well...
You should NEVER be in a position where a failed hose can KILL you. Remember a NEW hose can fail too...
If a tire blows, it probably won’t kill you.
Better chance on my motorcycles.
JOHN DEERE 1705 - 6R30" VACUUM PLANTER (A64277)
JOHN DEERE 1705 -...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2020 Kawasaki Mule Pro DXT (A62613)
2020 Kawasaki Mule...
2016 COTTRELL CX09LS2 T/A CAR HAULER TRAILER (A59914)
2016 COTTRELL...
