BX24 blowing hydraulic filters
   / BX24 blowing hydraulic filters #81
Would you care to explain how the problem is the loader valve?
It's either a hose hooked up wrong or it's bypassing inside the valve and sending straight pressure into the return and blowing the filter
   / BX24 blowing hydraulic filters #82
@rScotty: Sorry for the slight thread hijack, but can the steering relief valve be in the steering valve? I have looked at the hydraulic schematics and the workshop manual for my 2022 Massey Ferguson GC1723EB and cannot find a separate relief valve for the priority (dividing) valve within the housing that MF refers to as "the control valve", which also contains the valve for the 3-point. There is only one relief valve within it and that is set for 1920psi.
Thanks, Dick
Yes the relief is inside the steering gear box
   / BX24 blowing hydraulic filters #83
When you disconnected the backhoe what did you do with the hydraulic hoses? Did you connect them together?
   / BX24 blowing hydraulic filters #84
Years ago, when I first got my tractor, I finally disconnected the BH to install the arms/3 point equipment. There are two hoses I disconnect and loop the two fittings on the tractor to complete the circuit. The quick connect felt and looked like it seated but when I rechecked the connector again, I realized the circuit was not complete/connected and this could have caused problems if I started the tractor.
   / BX24 blowing hydraulic filters #85
Thanks, Dick
No problem. PM me the hydraulic schematic or open another thread & we can discuss that Massey GC. But the answer is yes, the steering relief valve can be anywhere you can run a pipe & fitting to. Combination diverter & relief valves are common and operationally interchangeable. Here's an example of a popular tractor combination valve:
   / BX24 blowing hydraulic filters #86
What you are saying is 100% correct if the BX had a return filter. The only factory filter on a BX is in the charge circuit not the implement circuit.
   / BX24 blowing hydraulic filters #87
Here is Dicktill thread....
   / BX24 blowing hydraulic filters #88
Thanks WranglerX. I suggest we start a separate thread for Dicktill's MF GC problem. Can you figure out how to do that & get it going. Maybe we just open a subject and copy these posts few GC posts
I hope this thread can stay focused on the BX and its specific filter/over pressure problem.
rScotty
   / BX24 blowing hydraulic filters #89
I’m sorry if this post is irrelevant. On my Branson tractor there is only two connections to change/remove the BH. In this BX24 video it looks like there are three hoses that require disconnecting, and only one hose is connected into the loop/system. If this setup is like yours, is there any chance the capped off/looped hose has been connected wrong?
   / BX24 blowing hydraulic filters #90
We have a BX24 and about 10 hours of work after disconnecting the backhoe, it blew the hydraulic filter. It was replaced and it happened twice more. We just changed the pressure relief valve and are waiting on a gauge to test. Anyone have any insight on this matter and are we missing something?
Any resolution on this?
2018 Ford F-150 (A55973)
2018 Ford F-150...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
New/Unused Gold Mountain 12ft x 20ft Steel Carport (A57454)
New/Unused Gold...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
