Skidder or Tractor? If you could only have one.
   / Skidder or Tractor? If you could only have one. #61
For me, a tractor is more versatile. I can use 3 pt attachments on the rear while still having the 4n1 bucket on the front. While a skid steer has much more lifting power and larger hydraulic flow, I don't need those things as often as I need the things a tractor can do. For example, carrying a load of dirt in the bucket and grading it after you dump it. You can do this with a tractor without having to stop and change attachments. It all comes down to your needs.
I do have a skid steer adapter on the front to allow me quick changes of bucket/forks, grapple, etc., and that is wonderful.
My buddy bought a tractor and a skid steer at about the same time a few years ago. He sold the skid steer last year because he didn't need it as much as the tractor.
Chris
   / Skidder or Tractor? If you could only have one. #62
Only made it to through the first 3 pages. As some others have said, it depends on the chores you need it for. Hay work or tillage, tractor all the way. Lifting heavy loads, moving a lot of material quickly and/or placing it precisely, maneuvering in tight spots, or operating on soft ground then the winner would be a skid steer. For me personally, a tractor does fine. I'm skidding logs, running a bush hog, plowing snow, and doing some general purpose loader work. If I put 25 hours on it a year, then I used it a lot that year so I'd rather have $10K-$20k sitting and waiting to get used than $20k-$60K.
An older friend of mine owns about 120 acres locally. Its mostly wooded with 2 small fields that he normally lets a local farmer use for hay. 30 years ago he was still running cattle on it, but about 20 years ago he built several firing ranges on it and made a business out of that. He had bought used 25hp Satoh back in the early 80s and used it for everything including building his house. When he started adding more firing ranges, he got a steel of a deal on a nice skid steer. I'm not sure he's even started the Satoh in the past decade. It's much better for digging into hill sides, moving large quantities of stone, ect. I've also done some volunteer disaster relieve work after tornadoes have gone through. A tractor with a grapple is useful, but a tracked loader with a grapple will run circles around it, and will do so on soft ground where you'd seat a tractor on its frame, and on hill sides that would roll a tractor. Most construction work is also better suited for a skid steer. The each have their place.
   / Skidder or Tractor? If you could only have one. #63
I have a firewood business and I havea Fransgard skidder that I keep on my JD 4400 they make some big ones for the bigger tractors about the only time I take mine off is when I use the brush hog , it is a good counter weight when lifting logs with my 4 in 1 bucket.
   / Skidder or Tractor? If you could only have one. #64
G'mornin.
I get asked when I will buy a skidder, usually by skidder folk. I say never and that I don't need one cuz of my tractor w/FEL and they look confused. Or wounded?
While I realize that seeing the cutting edge would be a huge advantage, I feel that a tractor is far better for rural living.
Your opinions??
Skidder
Skid Steer
Which one are we talking about?
   / Skidder or Tractor? If you could only have one. #65
My skidsteer would never have been able to pull this load through a deep mud hole coming out of the woods like I have to do at times,
OR through deep sand like I had to do today, no problem at all with my tractor though.
SR
   / Skidder or Tractor? If you could only have one. #66
In my tractor buying journey I started thinking a skidsteer was the ideal machine for a number of reasons outlined in this thread.
All it took was driving one down a small incline on my land to disabuse me of that opinion - I didn't even have a load in the bucket and wasn't going fast and it wanted to roll.
I can definitely see their uses, and no doubt the tracked units are more stable, but those tracks bump up operating cost quite a bit and given that half of my property is hilly and rocky it seemed that in my case, a tractor was by far the better choice.
For the op, the only answer I can give is: "it depends".
   / Skidder or Tractor? If you could only have one. #67
I do one kind of work with my tractors and another with my skid steer, they both have their place and are as a whole polar opposite.The places I put this skid steer I would never put my tractors.
   / Skidder or Tractor? If you could only have one. #68
each machine has its strengths and weakness and those very in the application they are used in. moving dirt around a house with 6 feet clearance skidsteer would run circles around a TLB all day long. On a farm towing a trailer full of dirt that you just loaded up TLB is great at towing ok at loading but would say its better then a skid steer.
But like every tool thier are sub versions tires or rubber tracks on a skid steer are epic different machines yet basicall called the same thing but ability is different.
my old track skidsteer could lift 2 ecology blocks not something a FEL is going to do until it's a much bigger machine.
so one machine... depends on the application and needs to do.
   / Skidder or Tractor? If you could only have one. #69
tire version are more stable then you feel and in some cases lifting a set of wheels up is a feature.
Track machine will go places a tractor could never go soft mud and side hills and they are way different than a tire version
   / Skidder or Tractor? If you could only have one. #70
Your skidsteer's hydraulics can lift 3600 lbs, but it will tip on level ground. If your on uneven ground or try to turn it will tip with less.
Your skidsteer at rated load should be able to go everywhere your tractor at rated load can. This is what makes comparing skidsteer vs tractor loads so odd.
Had a few times the wheels on one side would tip up due to the teeter totter affect of a skidsteer. I would have to lower the boom quick until the pipes hit the ground to keep from going over, With a tractor I never had that issue.
I never brought up the tipping and inability of my skid steer to go where most everything I own can, except the low cars.
Not talking about crossing irrigation ditches, but very shallow drainage ditches. Normally I cross those diagonally, either because of approach and departure angles, but mostly to avoid risking spinning tires.
Admittedly, I haven't even tried doing it with the skid steer. Decades of four wheeling tells me it'll fail miserably. Granted, it has much shorter wheelbase than the Challenger, but about the same ground clearance - or lack thereof. And at least the Challenger has suspension. I'd try with the Challenger before doing it with the skid steer, if for no other reason that the car is guaranteed not to end up on its side.
I also feel much better about side hilling a tractor than the skid steer. Of course, that could be lack of experience (and feeling trapped), or it could be that tractors are a lot more like Jeeps.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2008 FORD F-750 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-750...
