Pictures from a skid steer mowing contractor
   / Pictures from a skid steer mowing contractor #881
Approx 100-150 to start?
Depending on new/used for certain items.
That’d keep me outta trouble for a few years!
If you get lucky, a municipal crew dump truck, in the f450-550 size; or medium duty, non cdl dump truck, pintle trailer, could be had for $15-25k. Look into the creative lease to own programs on the skid steer. Yeah, you can get deals on a used skid, but got to look at down time, and if you are wanting to be a half time mechanic and half time operator, and how little time that leaves to bid jobs
   / Pictures from a skid steer mowing contractor #882
These businesses also tend to morph based on your clients. So, a tracked skid, mulcher, and 1 ton truck might be the correct to for Mr Lineman; but your local area might call for a 8.5T hoe with mulching head, or more small material deliveries. Florida might have readily available lease truck dump trucks; but your area might require frequent 8-12t deliveries, and hard to find lease trucks.
So, I would heavily consider leasing while to start up, and figure out your niche.
   / Pictures from a skid steer mowing contractor #883
Also, just to be contrarian; a 75ish HP tractor, and a 72" Brown Tree Cutter, might be a smart place to start? That gets you in the door, with new equipment for probably $75,000; and then short term lease of heavier gear, as needed.
   / Pictures from a skid steer mowing contractor #884
Our area is rural/farmland/overgrown forest areas. I see a couple guys with skidsteers-mulchers.
A lot of overgrown tree lines around me.
Been watching an auction tonight and have seen plenty of enclosed cab CTL's with less than 1000 hrs going from $29k-40k, it's getting cheaper to get in this game.
   / Pictures from a skid steer mowing contractor #886
Some customers are like clockwork and I can count on hearing from them yearly and they recommend me to their friends which is new work for me, I also have a friend who drills wells and he meets with new people moving into our area needing a water well drilled and lot's of them want work done and he gives them one of my cards and I get a lot of new customers that way, sometimes I get busier than I want to be and then winter will come and it slows down so I can hunt and enjoy myself for a few months until it seems to start back up, I am truly blessed and a very fortunate man.
Thanks and that's very good to hear! I'm glad life is being good to a hard working man.
   / Pictures from a skid steer mowing contractor #887
Todays auction. Yeah, at 2800 hours I would say it's at about 66% used up, likely not a high flow machine, no forestry package, but at $14k....
   / Pictures from a skid steer mowing contractor #888
I recently saw a short video, discussion machine hours, and their preferred Commercial, service life. They said HPx50 hours is a good guideline on selling and replacing a machine, while it still has good resale value, but you have used about 50% of its meaningful lifespan. They did also point out, at that 50 hours/HP mark, it still had a lot of life in it, but that it was a good line to look at replacement, again, in a commercial use setting.
   / Pictures from a skid steer mowing contractor #889
Sometimes I get busier than I want to be and then winter will come and it slows down so I can hunt and enjoy myself for a few months until it seems to start back up, I am truly blessed and a very fortunate man.
Charlie, thank you for posting that. I'm trying to get better at stepping back and realizing how fortunate I am. Keep up the good work!
Yes sir, God has a plan for every one of us, sometimes we just have to slow down and listen, have a good week.
Wolverine Quick Attach Post Hole Digger w/ Augers (A59814)
Wolverine Quick...
John Deere 5105M (A53317)
John Deere 5105M...
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
