Which coolant?
/ Which coolant? #1
dstig1
Super Member
W Wisc
Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
The Grand L5240 with cab in my sig. Overdue for a coolant flush and fill. I'm always a bit wary of coolants these days as there are so many types and mixing some of them can create big problems. I THINK Kubota uses regular old green coolant, like classic Prestone, that has been around since dirt was invented, but I wanted to check here to verify before I commit.
The manual is a bit vague saying to use "Long Life Coolant, Ethylene glycol type" but doesn't talk about IAT or ELC or any of the other acronyms used to describe coolant types.
Please enlighten me.
Thanks,
Dave
/ Which coolant? #2
You are correct.
OEM fill is plain old green.
Others will suggest newer long life coolants,but green will be fine.
Good Luck!
/ Which coolant? #3
I put this in my B3200. Green stuff was in it originally. Drained and flushed with water a couple times put this in. This is more red/orange color, formulated for diesel engines. Prevents cavitation around sleeves.
/ Which coolant? #4
My L2501 manual specifies an ethylene glycol antifreeze - which is the old fashioned stuff. Anything compatible should work.
/ Which coolant? #5
I put this in my B3200. Green stuff was in it originally. Drained and flushed with water a couple times put this in. This is more red/orange color, formulated for diesel engines. Prevents cavitation around sleeves.View attachment 3582129
Kubota diesels ARE NOT wet sleeved engines they are dry sleeved as in pressed in sleeves so coolant NEVER touches them. No need to buy expensive long life coolant or coolant that is made to prevent cavatation, as there in none.
Kubota specifies in their manuals, plain old green colored ethlyene glycol. You can use anything you want actually, but no need to waste money on high tech coolant.
Just drain and flush regularly and keep the rad clean outside.
Again, use anything you want, just make sure you flush the cooling system before changing as some coolants aren't compatible with others.
/ Which coolant? #6
I run Prestone in all my engines. The All Vehicle formula in the yellow jugs. I mix some concentrate with the 50/50 pre-mix to get my freezing point good for minus 40 for where I live.
reason I switched back to Prestone was it makes it easy for me because it's readily available and works in everything I own. And it's good for 10 years, though I don't go that far between changes.
Prestone also still makes the old style green in a black jug called Prime, but it is only good for 1 to 2 years.
/ Which coolant? #7
For diesel engines, run the cherry/pink color.
I switched to that in most of my engines for anti-cavitation and long life.
/ Which coolant? #8
Your use of coolant depends entirely on if your engine is wet sleeved (coolant contacts the liners directly or if the cylinder sleeves are pressed into the block (dry linered). As I stated, Kubota engines are all dry liner engines, consequently there is no issue with cavatation, so you can use origional green glycol coolant.
Other makes of tractors you need to check with yiur dealer on the respective shop manuals to see what the manufactirer recommends as I only know about Kubota.
Having said that, I also use conventional green gycol antifreeze in my Caterpillar 3406 even though it's a wet linered engine, but I add a sufficient quantity of DCA 4 additive to the antifreeze, based on what my Brix Refreactometer indicates as well as what the Ph test strips indicate. DCA 4 is an additive specially designed to combat cavitation in wet linered engines and it's available at any heavy truck dealer of repair shop.
Esentially, DCA 4 is a solution of Potassium Permagnate and distilled water and the Potassium Permagnate 'coats' the liners with a film that prevents liner cavitation which is essentially what happens when non treated collant contacts the hot liners, forms a gas bubble and explodes, causing a divot in the liner that keeps growing until it erodes itself through the liner entirely and compromises the combustion chamber, eventually causing engine failure. Of course none of that occues with a dry linered engine.
Having said that, I still renew my antifreeze every 2 years plus I flush the cooling system at the same time.
You can purchase an add on coolant filter (spin on) that contains a block of Potassium Permagnate plut the filter, filters out any debris present in the cooling system. My Cat came with a spin on coolant filter but the filters I run don't contain the Potassium Permagnate block, just the coolant filter.
LIke I said, I change my coolant every 2 years no matter what because the heat and cool cycles of the antifreeze depletes that additive package.
Again, be apprised that not all coolant types mix with each other so if you change coolant, it's wise to flush the entire system, more than once, to remove any old coolant before adding new coolant.
What my mileage is, yours may differ.
/ Which coolant? #9
Once again, your Kubota, like ALL Kubota's are dry linered engines (liner is pressed into the block) and is never in direct contact with coolant, consequently there is no need to add or change to a coolant designed for a wet linered engine. You can buy the cheaper green glycol coolant or whatever you want to, don't matter. There is no advantage to using antifreeze formulated for a wet linered engine because your engine is dry linered.
/ Which coolant? #11
Even though this excessive coolant, I've been using this since I did my first coolant flush 15+ years ago. Holds up well and it keeps the inside of the radiator clean, and it keeps the water pump seals lubed. So I can vouch it does work well long term, at least in a BX2200 that does have hot suppers occasionally.
Coincidence that I just did a full service on my BX two days ago and one of the items of interest was doing a coolant flush, and this post.
Very pleased with this coolant.
/ Which coolant? #12
Have you bothered to look and see of your engines have pressed in liners or liners seated against 'o' rings and in direct contact with coolant?
Heck, you can use Jack Daniels as coolant ina dry linered engine if you desire.... :rolleyes:
/ Which coolant? #13
Most owners are very lax in changing coolant but it's important to change it every couple years anyway. The heat-cool cycles of antifreeze depletes the additives in it.
/ Which coolant? #14
I've never done a coolant and oil analysis on my Kubota, but I regularly do them on my diesel truck to keep tabs on any potential issues. Diesels are extremely hard on coolant and oil. Ounce of prevention is a pound of cure I guess. ;)
A few years ago, I did a routine coolant analysis on one of my diesel rigs, and found the EGR cooler was failing. By the look of the coolant and basic proportion checking, you'd think there was nothing wrong. But nope, the test came back with slightly elevated amounts of combustion by product and soot. None of which should be in coolant. Took the EGR off and did a pressure test on the coolant ports and sure enough wouldn't hold pressure for 30 minutes. Nipped it in the bud before it made more work or caused a serious leak.
/ Which coolant? #15
I rely on Blackstone Labs for spectroscopic analysis but I do every other change. Coolant as well in the tractors and diesel truck. Fords are notorious for sealing ring failure in the oil / coolant heat exchanger.
/ Which coolant? #16
I used to use Blackstone, but I changed to Polaris (Cummins) for a while now, as they have sub-24 hour turn around times after receiving the sample.
Everyone seems to have their own opinion on both labs. I just use what I feel like is best for me.
/ Which coolant? #17
At work, we used Cummins for analysis. I don't have an issue with Blackstone's turn around time but I agree, they arent the quickest around and they just increased their analysis cost.
/ Which coolant? #18
I buy my Cummins test kits right from the local Cummins dealer. I buy in bulk to have them on hand and they give me a slight discount at the same time. It also goes into Horizon for each unit. Helps me keep tabs on things.
Only thing I don't like about Horizon is the interface is clunky and confusing sometimes.
/ Which coolant? #19
It's my understanding that most Kubota engines are parent bore-i.e. no sleeves.
Just the cylinder bore in the block.
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
1996 Sunflower 1543-38 Folding Disk (A63688)
1996 Sunflower...
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
