   / Your last generator Maintenance Run
This produces very clean power which is one of the first things I noticed after install. I am a ham radio operator and I installed commercial grade surge protectors at the breaker boxes for the house, barn, garage, and outbuilding and these also have an interference filter in them (RFI filter along with MOVs and gas discharge tubes). When running off the gas generator, I could hear the metal boxed suppressors "singing" along with the generator but now they are silent and this generator produces a beautiful sinewave on the scop. With the generator installed in the semi-basement part of the barn it is extremely quiet running at 1800 RPM and it can only be heard with the windows open. I should have installed it years ago, it has been well worth the cost and effort!
Rodger
Rodger - I'm curious about the Make/Model of surge suppressors you installed - labels still accessible ?
Rgds, D.
   / Your last generator Maintenance Run #7,512
Rgds, D.
Dave,
Attached is the photo of one of mine, I use one at the service entrance where the main line comes into the property and my transfer switch is located and then the barn, garage, tractor outbuilding, and house breaker panels all have their own units. They have to be connected through a 50 amp dual pole breaker, they are designed to fail with a dead short if they are hit with a surge beyond their capabilities so you do want to check the breaker from time to time but I have not had an issue with any of mine in decades of service.
But now the bad news, the company is no longer making these mains type protectors even though they allude to them on their website so hopefully they are coming back.
ICE is now Morgan Systems and they still make a lot of great products but they don't list the suppressors I bought. I also used one of their units on the phone line when I had a landline and my ham radio antenna rotors and antenna feedlines are protected by them: https://www.surgestop.com/
I am going to reach out to them via my business account when I get some time next week to see if they have plans of bringing the mains type units back because they work very well. Shortly after I had a new well put in back around the year 2000, the company I use started installing a bunch of VFD well pumps and the fairly sophisticated control boxes that provided the 3 phase variable speed drive to the pumps were failing at a high rate due to lightning surges. They started installing one of the ICE surge suppressors every time they switched a customer to VFD and the failure rate went to near zero. The only downside of them is the gas discharge tubes clamp very hard and very quickly so you will see some light flickering when a storm approaches as they briefly clamp the line every time a surge exceeds their triggering point.
And on edit, this company also has some excellent tech papers on proper grounding techniques for lightning protection and related subjects: https://www.surgestop.com/tech.html
Rodger
Dave,
Rodger
Excellent 411 ! Thanks for posting all those details Rodger.
If you get some updates from that company, please post again. Even pre-tariffs, accessing quality products in a small market like Canada is challenging.
I've had a few discussions over time about VFDs with my neighbour (HVAC contractor); I should see what he may be using these days.
Rgds, D.
   / Your last generator Maintenance Run #7,514
This has been a fun thread to read. Thanks for all your posts.
I have a maintenance run coming up soon and will post about it.
   / Your last generator Maintenance Run #7,515
Mine auto started this morning shortly before 6 after a brief interruption. I decided to turn it into an exercise cycle so that it would get up to operating temp under load instead of shutting back down after monitoring the line for 5 minutes for another power dropout.
The cats didn't appreciate me turning the thermostats down on both central AC systems to add more of a load because in their view the HVAC system is broken unless there is hot air coming from the vents :)
Very dense fog this morning so probably an insulator somewhere had a major arc and caused a quick drop and automatic restore.
Rodger
Back When, I wanted an ongoing Reminder to Self..... (still needed, by me :cool:), and figured maybe a couple of people would stop by.....
It's been a lot of fun here, and showcases the best aspects of TBN. We've gotten very well detailed accounts of solid, well-engineered installations of all sizes, and along the way, helped sort out some ailing generators. Ongoing reviews and feedback about generators and add-ons/enhancements..... priceless data, IMO. Yes, thanks to all who post here !
Rgds, D.
Rodger
Da Kats, taking one for the team !
Your comment about flash-over, reminded me of seeing a crew, many years ago, power-washing insulators from a bucket truck. I haven't seen that being done, in quite a while.....
Rgds, D.
   / Your last generator Maintenance Run #7,518
During the extended power outages here my Honda EM 5000 powered the refrigerators at 4 single family homes plus modest lights and computer/cell chargers…
My then 95 year old neighbor was in charge of rolling it out and laying all the 10 gauge cords.
Originally it was just for my house but I was often away so he took over for my place, his place, his daughters place and we added the 100 year old widow lady next to his daughter…
The Honda has been zero trouble since I bought it new in 1985…
what a nice looking generator, you clearly took good care of it
and are those steel wheels? real steel? :giggle:
I think I've only seen plastic
truly built to last
   / Your last generator Maintenance Run #7,519
truly built to last
Good question… will have to check.
Right after I bought it in the early 90’s the same neighbor gave me a genuine Honda factory cover for it…
Good neighbors are priceless…
   / Your last generator Maintenance Run #7,520
Have to drag my Troy bilt 5500 out tomorrow and clean it up and get it running. Hasn’t run in probably 10-12 years since I got the generac whole house unit. Electrician is changing out the panel box and wiring in the new generator at the job on Tuesday. And I need power for saws and compressor.
2021 MacDon FD135 Flex Draper - 35' (A59814)
2021 MacDon FD135...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
207280 (A52708)
207280 (A52708)
