Help Needed in Edgewood NM for Service on a TYM 293
   / Help Needed in Edgewood NM for Service on a TYM 293 #1
kenb1023
Edgewood, NM
2019 Cub Cadet XT1 and 2010 TYM T293
I have a TYM 293 that needs some work but there are no TYM dealers within a 100 miles. Shiprock is the closest TYM dealer now. The one that I bought the tractor from went out of business. I need to get both rear axle seals replaced (I have the seals) the front axle left seal and some other odds and ends. If anyone knows of a person in the Albuquerque area that can work on the TYM please let me know. Its a good little tractor, just needs some help.
   / Help Needed in Edgewood NM for Service on a TYM 293 #2
Yes, check the Mahindra dealer down on Broadway, just north of the Isleta exit.
LR Sales, their number is 505-877-9410. They may be able to help.
There is another place, right on 66 across from the Tijeras transfer station. They do a lot of heavy equipment repair and may be able to do the work. I think they do it "part time" so tough to say. I don't know the name/number. They sold me 2- 8' cutting edges for $50, so really cheap.
   / Help Needed in Edgewood NM for Service on a TYM 293 #3
What part of Edgewood are you in?
   / Help Needed in Edgewood NM for Service on a TYM 293 #4
Ken, If your mechanically inclined at all you can do the seal swap yourself. I've done it on my 273 and it's tedious, takes a lift of some sort to remove the ROP, and some time to dissemble the axel portion, but -- it's a doable job for a homeowner. Just keep track of what you remove and it's just a reversal to reassemble. Good luck, Greg
Thanks. I did call the Mahindra dealer. The person from service that I talked to was short and rude. In short he said that they only have time to work on their products. If I was considering to get a new tractor this person sealed the deal for me to never do business with this dealer. I will look into the on 66. Thanks again.
Greg, I am mechanically inclined but this is an area I don't feel comfortable with. Additionally, I don't have the ability to get the ROP off. The tractor is what I use to lift heavy things like this.
   / Help Needed in Edgewood NM for Service on a TYM 293 #8
Ken, I hear you and it does take some sort of lift to remove the rops. I have an old harbor freight engine lift I used. Without that I couldn't have gotten the job done. But, all of the rest is just mechanical stuff that I'm sure you could accomplish. If you can figure out some way to remove/reattach the rops you're on your way to fixing your dilemma.
Believe me Ken, I'm not just preaching at you, this can be done! I was "very" nervous and unsure but plunged ahead because I needed this to get done and had "NO" one else to do it! With the parts/service manual just plug along and get-er done!
Or - if you do find a mechanic, be prepared to pay an exorbitant sum. Again, Good luck.
   / Help Needed in Edgewood NM for Service on a TYM 293 #10
Yeah, that's why I don't own a Mahindra. Even if you're looking to buy a new one..... well lets just say that they pretty much drove me off with their attitude.....
3650 (A47477)
3650 (A47477)
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Towable Sprayer (A59228)
Towable Sprayer...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
