John Deere D170 wiring diagram wanted
   / John Deere D170 wiring diagram wanted #11
Looking for some help. Have a 10 year old d170. Blowing 20A fuse when trying to engage the mower deck. Just changed the pto switch yesterday. Mower runs and drives but blows fuse and will not keep blade running when you change it. PTO clutch? Tried to read the wiring diagram but it's fuzzy when you zoom in. I don't know what the parts are.
   / John Deere D170 wiring diagram wanted #13
Unplug the connector at the top of the clutch and see if it blows then.
   / John Deere D170 wiring diagram wanted #14
Here is the wiring diagram:
   / John Deere D170 wiring diagram wanted #15
The 20 amp fuse goes to the voltage regulator. Could be a problem there.
Richard
   / John Deere D170 wiring diagram wanted #16
Highly recommend bypassing the seat safety switch. Yes, I understand it is a safety thing and should be left in use, but it's not always practical. My front yard has a steep incline that I actually have to sit on the fender for to mow.
I also disconnected the reverse override button. Another great help.
   / John Deere D170 wiring diagram wanted #17
Here's what you do Bronco. Get your self one of those lanyards for a jet ski and wire it into the seat switch. Clip it to your pants. I have a yard that's much the same but there ain't no way I'm tumbling down the hill w/ a running mower deck. It just might just save you.
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
207276 (A52708)
207276 (A52708)
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
Mower King Brush Cutter (A53317)
Mower King Brush...
