Engine loses power
/ Engine loses power #1
jimjumper
Hemet, CA
Yanmar 240D, 8N Ford
My 8N, front mount distributer, 6V stumbles on the slightest uphill and will die if the incline is steep enough or long enough. Nothing changes on a downhill. I recently put a new carb on it since it sat for some years as well as a new fuel line. My first inclination is/was the governor and when I checked I noticed the linkage rod from the governor to the carburatuer has about 1/2" of slack. Thats a bad description but what I have is the linkage rod is not seated in the spring connectors but is loose and can slide back and forth between the 2 connectors. I assume it should be a solid linkage? My other thought was that maybe the carb floats weren't moving when the tractor went uphill and it was starving for fuel but would correct itself on flat ground. Do either of those things make any sense or am I just guessing? The tractor runs great otherwise but hit a good uphill bump and it will cough a couple times and then go right back to running right. Anything steeper and it will continue to sputter or die.
/ Engine loses power #2
I would start by making sure the float is adjusted within limits and the needle valve is free to move, not sticking.
/ Engine loses power #3
It sounds like float to me. That is the first thing I would check. Do you have an owner's manual? It has instructions on setting float height and adjusting the governor rods. I can post the info here if you do not have one.
/ Engine loses power #4
Sounds to me like ignition... more good fuel systems have been screwed up by a bad ignition. Check to be sure you a snappy blue spark, if it is yellow there's yer problem.
I checked the floats and they looked fine. Throttle linkage and governor linkage looked fine. Put it back together and went to drive it around with similar results, any slight uphill causes it to stutter and cough and then die. BUT! when it died, I restarted at idle and then throttled up halfway and backed down to level ground. No problems. Got curious and backed up a much steeper hill and it had full power all the way up! Did it 3 more times with full power each time. I could hear the governor apply power as it climbed so I don't think the governor is the problem anymore and it likely isn't ignition so I am left with carb or fuel? Any idea what to check to find out why I have power uphill in reverse and not nose first? It has me baffled.
/ Engine loses power #6
Is the fuel tank full?
/ Engine loses power #7
check the fuel pickup tube in the tank for a hole/corrosion/crack.
/ Engine loses power #8
My 63 2000 had a dirt-debris problem from the fuel tank. Showing up in the bottom of my Glass sediment fuel bowl. looked like fuel tank rust along with the fuel valve itself was leaking. Cleaned and placed the valve and lines and it finally quit showing up. Took a while cleaning the sediment bowl several times and it pretty much stays clean with hardly any dirt showing up in the bowl. The shop who split it warned me to keep an eye on it. They replaced the fuel valve. My tank would pressure up also. That seemed odd but you could hear it opening up the fuel cap. I drilled a hole in it and made sure it vented!! New Carburetor kit could be possible?
IMO. I would remove and clean the carburetor Esp. the fuel bowl, float, needle etc... The Elec. Sys. sounds as though it's working ASIS.
Filled it with gas and no difference. It did have 3.5 gals so i don't think that was it. It has a brand new gas tank but I used the old cap. I'll try a different cap and then start backtracking thru the fuel shut off (also new) and then the carb.
/ Engine loses power #10
Does that have the mixture adjustment screw on the bottom? Maybe it's running way lean.
I went through three "new" carbs on my 9N before I got a good one. They're really a simple device, but the original one was cracked so I had no option to rebuild it. 12 volt and electronic ignition conversions sure made it more reliable too.
/ Engine loses power #11
Try starting fluid or Either since it's gas. How I found out quick it was a fuel problem. Not on my Diesel though
/ Engine loses power #12
I don't have experience with an 8n but my old Farmall has gravity feed from the gas tank and if the gas is low it will act like that. More than once I have backed up a hill when it stalled.I first though that you may have a restriction in the fuel line but the fact that it backed up the hill pretty well answers that question.
/ Engine loses power #13
Make sure the points and condenser screws are really tight. Back in the 70's I had a chevy belaire that I would tune up myself. AC Delco came out with the "uniset" which combined points and condenser on one metal plate. After i particular tune up when I couldn't locate a uniset, I swapped back to the original set up and forgot to tighten the condenser screw properly. Once the car bucked or bounced it set in motion a constant bucking that was caused by the condenser, now suspended only by the wire to bounce in a rhythmic fashion only touching ground occasionally. I don't want to be reminded of everything I went through till I pulled that distributer cap back off !!
I think I've solved it. Since uphill backwards was full power that would eliminate the tank and fuel line. Same with the carb fuel filter. Checked the air intake for obstructions and nothing. Ordered new, better quality, carb and installed. Set the needle adjustments exactly as the FO-4 says. Started it and idle was good, backed power needle a half turn and bingo! Just ran it for 10 minutes and it ran great uphill, downhill, and under load. I'll put some time on it tomorrow just to nmake sure it wasn't a fluke but I at least know where to start if it does it again.Thanks for the help and suggestions!
Damn, I hate it when I'm stupid! I was using ti mowing with it running fine and hit a big squirrel mound in the brush. Tractor quickly! bogged down and died. Restarted pretty easily but when I ran it to full power it started popping and running rough again, in both forward and reverse. I don't really know why it affect the carb but since it was running smooth just before, I'll pull the carb and check. Or may be the governor bent something?
/ Engine loses power #16
The sudden engine stop may have caused the cam timing to jump a tooth or two. I'm not failure with the 8N, but if it has a timing chain, it could be worn out and needs replacing.
Put the new carb on it but while it made some difference it still starts to run rough under load. I put a spark checker on it and discovered that while it sits at idle I get an orange steady spark but pick up the rpm's and the spark gets erratic to non-existent. I only checked one cylinder since it was hot but I'll check all 4 tomorrow. The tractor had a bad generator when i started this renovation and the current 6-volt system has been rebuilt to the system on a 9-N with a brand new cut-out switch and generator. The guy that I purchased the generator from was meticulous in the directions on how to wire it that way and I confirmed with him thru pictures that it is wired correctly but now I am having doubts. The ammeter shows +9-10 amps when running at full power but since I am only getting an orange spark I am assuming I am not getting full power to the plugs? I also assume that I should work that first before I pull the distributor and make sure the timing hasn't jumped as some have suggested. What would cause low power to the plugs? The battery stays charged and I haven't had problems starting it.
/ Engine loses power #18
Coil polarity?
This is exactly! how the wiring is currently. Since I don't have headlights there are only 8 wires total. I have taken pictures and verified it independently so I'm pretty sure the wiring is correct. However, I just did the 3 tests shown on the diagram and did only get 3V across B and C. I'll try a new resistor block and see but I aint getting my hopes up.
If I jumper'ed across the resistor would I be able to tell if the voltage to the coil increases? I realize that would be hard on the points but it would only be a minute or 2.
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
2018 International HX620 Quint Dump (A62613)
2018 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
