Help! Tractor bounces with implement raised.
/ Help! Tractor bounces with implement raised. #1
jcoffeen
Mahindra 3510
My Ford 1910 bounces when I lift an implement on the 3-pt hitch and the front loader operates a little slow. I just replaced the hydraulic oil filter and I just replaced the U seal on the hydraulic piston, which was in bad shape. The hydraulic oil level is overfilled, but I don't see any evidence that this could cause the problem. The service manual is NO HELP at all in troubleshooting this. Anybody know what the problem could be? I'm stumped because I really thought that replacing the bad seal would fix it.
/ Help! Tractor bounces with implement raised. #2
Does the 3 point lift in jerky movement and then hold position or is it drifting down and then lifting back up?
If I raise the implement off the ground, regardless of how high I raise it, the tractor bounces real bad. It will hold that position but with bouncing. Something important that I forgot to mention is that although I just replaced the seal on the hydraulic piston, the implement lowers to the ground when I turn the tractor off (and yes, I installed the seal in the correct direction with the U facing the front of the tractor). This makes me wonder if something is wrong with a valve or something.
/ Help! Tractor bounces with implement raised. #4
Prob just have air in the cylinder
/ Help! Tractor bounces with implement raised. #5
what was the reason you replaced the lift cylinder seal? Did the old one look bad when you removed it?
Not familiar with your tractor but did you have to dismantle the valve and connecting linkage to repair the cylinder? If yes is that all reassembled and adjusted correctly?
Air would make it bounce but cycling 3 point a few times should have removed air from the circuit
/ Help! Tractor bounces with implement raised. #6
Does turning the drop speed adjustment knob under the front of the seat change anything?
It is possible that valve needs new seals. If the seals are shot, that valve could be letting out of the 3pt hydraulic cylinder almost as fast as the pump can replace it.
I've read the service manual and don't see anything about bleeding air out of the lift cylinder. Is this something you've done before?
I replaced the cylinder seal thinking it would solve this problem of the tractor bouncing and the 3 point implement dropping after shutting the tractor off. I was surprised to see that a brand new seal didn't help the problem at all because the seal was almost completely disintegrated. Replacing it was very simple and I didn't have to mess with any linkages or valves or anything - the cylinder assembly just slides out with the flow control valve plate under the seat. I'll cycle the 3 point up and down a few times and see if anything changes.
Yes it does. Let me give you the details. If I lift the implement up, it bounces like crazy (shakes the tractor vigorously) until I turn the flow control knob all the way off and then it doesn't bounce at all. If I turn the tractor off and leave the flow control knob all the way closed, my blade stays up now without creeping down, so the new seal fixed that problem. But, if I turn the tractor off and then open up the flow control knob, the blade drops to the ground. I tried posting some videos but they're not allowed. Which valves are you thinking of: the flow control valve assembly or the 3 pt lever control valve assembly? I attached assembly views of both valve assemblies.
  • valves.pdf
/ Help! Tractor bounces with implement raised. #10
The flow control knob when it is operating correctly only controls the speed of the drop of the 3pt arms. It is for drop rate only. Your 3pt cylinder sounds like it is losing fluid and then refilling. That could be due to the drop rate knob being bypassed internally because some of the O rings on the drop rate shaft are missing.
It could also be due to the main 3pt lifting valve stop being missing or misadjusted. More about that below.
The new seal - I assume you mean the piston seal - sounds like it fixed the problem of fluid bypassing the piston-to-cylinder walls. But that new seal doesn't do anything for the other leakage path past the drop rate knob O rings.
Maybe both. The drop rate knob is easy to remove and service. Basically a long needle valve with some O rings on it. The only reason I suggest that drop rate knob at all is because it could cause that problem and it is easy to R&R. Always do the easy things first.
If yours has an internal cleanable crud filter screen in the hydraulic sump make sure that is clean. Often overlooked & could also cause the problems you have. I think the older Fords have that screen.
Frankly, yours sounds to me more like the 3pt lever control assembly is out of adjustment. Or a relief valve is stuck open....can you hear anything? The control \could even be missing one of the springs or nuts that adjust spring preload on the main lever control assembly. That happens so rarely that most mechanics - including myself - rarely adjust one. I'd probably start by comparing all the external springs and nuts with a known good one.
Here is a general overview of how any 3pt hitch operates:
luck,
rScotty
/ Help! Tractor bounces with implement raised. #11
Double check the draught control knob position. I had a similar problem on a JD, and the problem was to do with the draught control. This was a long time ago so I don't recall details.
/ Help! Tractor bounces with implement raised. #12
One thing no one has said anything about is the feed back control. Some have a spring on the shaft and the control to the rock shaft can move, but if rusted or real dry can chitter on the rod. That well make the 3pt jump up and down as you go up, just grease or oil it. Like redman said if you have draft control.
/ Help! Tractor bounces with implement raised. #13
Crank up the RPMs, does it smooth out? Also found the setting the drop rate adjustment to just barely open helps. It's PITA slow when you lower the 3 point, but does mitigate the bouncing.
/ Help! Tractor bounces with implement raised. #14
Like someone else mentioned.... does this tractor have draft control?
Everyone, thanks for you suggestions. I found the culprit. It was this little spring (circled in red) that pushes against the steel ball inside the flow control valve. It looks like someone took it apart in the past and when they put it back together they must have crushed the spring with the valve body (#6 below) because it was all deformed/mangled. Works fine now.
/ Help! Tractor bounces with implement raised. #16
Mine did that with a brush hog on te back and it was the seal on the hydraulic piston under the seat for the 3 pt
/ Help! Tractor bounces with implement raised. #17
Thanks for posting the solution.
rScotty
Volvo EC220EL (A60462)
Vermeer 604 XL-Series (A62177)
Vermeer 604...
2011 AMERICAN 14 T/A DOG HOUSE (A63569)
2011 AMERICAN 14...
2016 KUBOTA SVL75-2 (A64047)
2016 KUBOTA...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
