FEL Control Valve Body, Banjo Fitting Seals
/ FEL Control Valve Body, Banjo Fitting Seals #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
I own a MAX28XL, 2014, 500 hours.
I have done a lot of earth moving, digging, Field work with it and the MAX has performed well.
In the last six month the FEL Control Valve started leaking, I finally decide to clean it up and found one of the Banjo Fittings is leaking.
I removed the fitting and found the Washer/Rubber Seal was leaking and it had gotten worse over the last six months.
So, I have looked on the Web for these seals but I have not been lucky enough to find one. I finally contact a Site called "Mahindra Parts Direct" !
They want $20.00+ for one, now I know we are talking high pressure, which means $$$, but $20.00 for one seal was just too much for me.
I am dealing with "Shearwood Tractor Parts" at the moment, waiting for a picture of the Seal, just to make sure it at least looks like the item.
I have tried three Hydraulic Shop in my area without finding something similar, so I am up in the air at what to do.
Does anyone know a Shop that sells Banjo Fitting Seals for flat surface mounting.
Any help would be appreciated.
Thanks for your time / GOD Bless
/ FEL Control Valve Body, Banjo Fitting Seals #2
Banjo fittings typically seal with either a copper washer or a bonded seal, also called dowty washer. These things cost less than $1 each and that's on the high side. Heck, $20 is probably a box full of those.
You'll have to measure the outer diameter of the banjo bolt to figure out the size of the dowty washer. It's most likely metric.
I don't how an hydraulic shop can call themselves an hydraulic shop without having this stuff in stock or even the will to help you out on something so simple.
A couple of sources:
That's them and I never thought of McMaster.
Thanks
View attachment 3533258 View attachment 3533259
Done !
Thanks
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
2013 Dodge Challenger Sedan (A60352)
2013 Dodge...
2021 JOHN DEERE 204L WHEEL LOADER (A62129)
2021 JOHN DEERE...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2019 John Deere 6125R (A60462)
2019 John Deere...
