Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,090
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Regarding my JCB loader/backhoe.
History: Nearly from day 1 of me owning this... I've owned it for maybe 25 years but, bought it used. Looked ugly as all get-out but, ran (and still does) as smooth as a swiss watch.
Starting procedure has nearly ALWAYS been (when engine cold)... climb up, hit start on key.... starter will click ONE time. Stop...turn key off....(starter might still be slowing down from spinning BUT, it didn't engage flywheel)
Turn key again.....another click...turn key off... wait 3-5 seconds, turn key again and BAM, fires up in what seems to be a quarter revolution of the flywheel (seems to be a fast starting machine, no cranking really needed)
Later after use, shut down...have lunch, climb back on and turn key and FIRST turn, fires right up. So the three key turns is done when engine is cold.
Other day, jumped aboard, turned key and dead silence. NOTHING. Key off, turned again, more dead silence. Absolute no click that it's done for 20 years.
Presuming battery is dead because I might have left key on for couple days (turned out I didn't).... bring tractor over, hook jumper cables and BAM, engine cranks and fires up. Ok so batter was low.... (turns out it wasn't)...
Shut down, hooked charger to it... next morning, jump aboard and again, dead silence. Connect jumpers and BAM, starts like a bat outta heII.... If the batter was dead or weak, it would take MUCH more charging while jumping.
My guess is my bendix has finally bit the dust. Maybe weak connection inside (hence the clicks).... but connect jumper cable to it...adds some boost and things rock & roll like they should.
My thoughts are, replace bendix. (maybe starter if I can't find just the bendix, I've not looked yet)
Agree??
Agree??
