Pulling a stump jumper off a Land Pride rotary cutter?
   / Pulling a stump jumper off a Land Pride rotary cutter? #21
I've removed them a few times. I just put a pipe through the access hole to remove the blade bolts and beat the pipe with a T Post pounder. Hit it a couple times, spin it to the other side, hit it a few times, and spin it to the other side and hit it a few times. Eventually, it always falls off.
Hadn’t thought of using a post pounder like that.
Thanks
   / Pulling a stump jumper off a Land Pride rotary cutter? #22
I saw it on YouTube and gave it a try. It took about half an hour, and I had my doubts, but then all of a sudden, it was off!!!!
It won, al least with me for now.
It broke my chain. Same setup as before only wits a single chain under the jack & used the blade bolts to hold it. Worked the blade carrier bar near the shaft with a torch until I could ever so slightly see a dull red spot. Pounded on it with a drift & sledge hammer from the top. More heat. Cranked on the jack a bit more & heard a bang. Thought I won. Cranked on the jack a bit more & the chain fell apart.
Sketch factor was already high & I don't need any more injuries.
   / Pulling a stump jumper off a Land Pride rotary cutter? #24
Try wooden wedge pairs around the stump jumper periphery.
   / Pulling a stump jumper off a Land Pride rotary cutter? #25
Do you have a T Post pounder?
Just put a pipe through the hole were the bolts go and beat it a few times with the T Post pounder, then rotate to the other side, and do it again. Then rotate it again, and again. Eventually, it will come off.
   / Pulling a stump jumper off a Land Pride rotary cutter? #26
Shafts on Bush Hogs are notorious for this. Seems to be the acid in the grass that welds it. I used a Harbor Freight 10 ton 3 jaw puller after breaking the 5 ton. Also an Oxy-acetylene torch to heat. MAPP gas is good, but couldn't get enough heat out of a small torch. I had assumed that I was going to chage the seal after that.
You can see the hoses of the new to me oxy-acetylene torch in the photo.
Ya, will give it a try. Beat on it with a sledge & drift while the jack had tension on things. At least its safer than loading up the chain like a 10 ton spring again. That was sketchy as hell.
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
Hot Pressure Washer Trailer (A59228)
Hot Pressure...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
