Suggestions on customize a carry all please.
/ Suggestions on customize a carry all please. #1
Tifford
Jordan
Mahindra 25 hst
I'm pretty sure I'm going to buy a countyline carry all at box store.
I noted one reviewer said he only carried 700 pounds (the ad says it will carry 1000 pounds) and bent the frame just below the two lower pins on the 3 pt hitch. So I'm debating on how to strengthen those vertical pieces of steel on both sides. Do I bolt on Oak 2x4s to each? Do I weld on extra steel and if so how thick of steel. Amature welder here with a Lincoln 135 flux core wire welder that plugs into a household outlet. Next, how to strengthen where the vertical meets the horizontal forks. Should I run something from just about the 2 pins down to horizontal forks to form a triangle or should I get a strong piece of angle iron and bolt it to where the vertical meets the horizontal?
In winter I burn coal. Was thinking of making some sort of box (low end at the end of the forks) made out of pallets that I can slide on the forks to carry coal for burning in my coal stove. I burn 40 pound bags and don't need more than 10 at a time.
I use the ash (after the burning process) my plan is to store the ash in metal trash cans to be used as a traction aid on the road I live on. I live on at the end of a 1/2 mile dirt road (with a 200 foot driveway) that's not maintained by the state. I live in Central NY. Gets icy at times and the ash makes for good traction much the same way the state puts sand on the main roads. Other than occasionally carrying tools: shovels, rakes, chainsaw, basic hand tools I can't see using it for much more.
I do pull 3 tires behind the tractor bolted in the shape of a triangle to groom the road but a D right bolted somewhere to it should make for an easy attachment point.
Suggestions please.
Thanks
Tim
/ Suggestions on customize a carry all please. #2
Suggestions please.
Thanks
Tim
Weld triangular gussets outside over and joining the vertical and horizontal bars.
/ Suggestions on customize a carry all please. #3
My bet is that the "bending" was due to a heavy load along with going over bumps at a good speed.
I have that carry all, and would not expect any sort of failure with a 1/2 ton load.
Now get things bouncing, and metal tears up all to rapidly.
And to strengthen the vertical piece I believe I'll get some 2x2 stock (typically the steel that slides into a receiver of a hitch to tow with) and put it against the two vertical pieces. Either weld or bolt.
I agree. 700 pounds can be 1500 pounds in the blink of an eye with a good bounce. In winter my mahindra 25hst stays in 4wd and is a steady but slow tractor.
/ Suggestions on customize a carry all please. #6
A large triangular gusset will be the best way to strengthen. Weld it.
Going to get one and beef it up. Lots of welding to do and some steel to buy.
Got a digging project to do and finish up by the middle of next week first
Thanks for the replies
/ Suggestions on customize a carry all please. #8
You can't really do much to supplement the corner where the vertical meets the horizontal members without giving up cargo capacity. But I will contend that that will be the failure point if the pin locations are reinforced.
/ Suggestions on customize a carry all please. #9
/ Suggestions on customize a carry all please. #10
I have that same carry all. I also put a bend in it carrying a heavy load on a bumpy woods road. I straightened it with the help of a torch then made a gusset piece like this out of 1/4 stock
Then I welded ot to the carry-all frame and drilled out the gusset bracket so the pin went thru both pieces.
I took the bumps slower after that but I wasn't afraid to load it up. Here's 1000 lbs of blocks
And a 1/3 cord of firewood
gg
/ Suggestions on customize a carry all please. #11
...pull 3 tires behind the tractor bolted in the shape of a triangle to groom the road but a D right bolted somewhere to it should make for an easy attachment point.
Suggestions please.
This might give you some ideas to make a lifter for your lane grader. And maybe light-duty pallet forks.
I cobbled together this rear forks assembly for a specific task 20 years ago. It's still in use and has never bent. Aside from carrying pallets, I use it to lift a light lane-grader as well.
p1050892r-jpg.70566
p1050890r-jpg.70567
I estimate its weight capacity is 800 lbs. This tractor's 3-point is rated 750 lbs and I had to remove some water before I could lift these three cans, 750 lbs plus 100 lbs for the forks and platform.
But no damage to the forks bouncing over rough ground.
p00069rwateronforks-jpg.72662
Next photo - lane grader under construction, also cobbled together from scrap. The cross chain is to lift it. Next construction step was short chains from each front corner, to hooks that grab each fork upright.
I lower the forks onto the grader for added weight on its front edge. I could put ballast near the middle but don't seem to need it.
If you want a permanent 3-point mount for your lane grader, it could be like this.
20210321_194855rlandplaneinshop-jpg.693293
/ Suggestions on customize a carry all please. #12
Instead of spending the money on a carryall, I bought this 3pt to SSQA adapter and use my forks with a pallet as a carryall. I have a deck box bolted to a pallet that I use to carry tools, chain saw, etc. It also keeps the FEL bucket free to carry the coal bags
The forks are rated at 4000#, much more than the 3pt will lift, so no worries about breaking anything.
I also burn coal and spread the ash with an SSQA 3pt spreader. When the road gets slick, I drop the forks and pick up the spreader:
When not on the tractor, the spreader sits by the back door and I just dump the ash pan from the stove into it.
/ Suggestions on customize a carry all please. #13
Mr. BDHSFZ6, since you've had good luck with your set up, do you recall where you purchased the 3pt to SSQA, and was it a specific brand?
/ Suggestions on customize a carry all please. #14
I bought mine from Titan per my link above. There is no label, so I'm not sure who makes it. It's pretty rugged though and I haven't managed to bust it yet.
Not cheap now, the price has gone up 40% since I bought it 5 years ago. There are cheaper adapters out there but I'm a bit concerned about strength.
/ Suggestions on customize a carry all please. #15
I just clicked the link
They are ON SALE! Save $200 ;-)
/ Suggestions on customize a carry all please. #16
Ahhh, missed seeing the link...Thanks!
RING 2 STARTS HERE @ 9:15 AM (A60432)
RING 2 STARTS HERE...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
John Deere 7410 (A53317)
John Deere 7410...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
4 BOTTOM PLOW (A60430)
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
