Broken connector near Valve Cover
   / Broken connector near Valve Cover #1
jebwhs87
John Deere 1993 425
I was replacing the Rocker Cover Gasket MIU11358, and when I put the cover back on (left side with the oil fill), I noticed a wire broken. It is a yellow wire with an L shaped connector (Yellow Box). I believe it was attached to the connector (Blue circle). What part do I need and how do I repair this?
   / Broken connector near Valve Cover #2
Greetings and Welcome. Is this a gas or diesel motor ? Looks like a spark plug. Take another picture showing the entire top of the motor showing scale and orientation.
   / Broken connector near Valve Cover #3
Is the motor water cooled, sort of looks like a temp sensor?
   / Broken connector near Valve Cover #5
I go first with water temp sensor, second choice may e oil pressure switch..... Take sensor base out and see what you get....
It is Gas and that is not spark plug wire, this wire is directly to the right of the OHV cover. Will try to get a picture tonight further back.
so the hex bolt in blue circle is what I should remove?
   / Broken connector near Valve Cover #9
That’s what I’d remove if it were mine, I think you will find antifreeze once you remove it. I think it’s a coolant temperature sensor, but my wife tells me I’m wrong a lot…
Do I need to drain the coolant (don't want it gushing out) before I remove? Looks like it is below the reservoir.
Wait...men are wrong??? That would be a first for me (as my wife hits me) ;)
JOHN DEERE 8345RT TWIN TRACK ROW CROP TRACTOR (A54756)
JOHN DEERE 8345RT...
2005 Ford F-750 Truck (A55788)
2005 Ford F-750...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
