Spindle
/ Spindle #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Any of you guys have any experience rebuilding mower spindles?
I’ve got one out of three spindles possibly bad on my tractors mower.
Lots of up and down play that I don’t think any amount of tightening is going to fix. ( could be wrong)
What typically causes this kind of wear?
I’ll have to figure out how to remove the top 3 groove pulley first.
I’d assume some type of bearing puller maybe?
New one is 400 plus so I am motivated to save this one.
Here is a schematic from the parts manual
I’m gonna guess that these mower spindles don’t change much from one manufacturer to another
/ Spindle #2
Make sure outside bearing doesn't have wear and still snug.
/ Spindle #3
A puller on the pulley is the best. Not hard to rebuild. Very similar to a wheel bearing repack.
/ Spindle #4
Rebuilding takes a press to move the shaft through the bearing inners.
I have three spindles off a "well rotted" kubota mower that was included with my B7200. (deck is long gone, and I can't imagine a way to insure these would work for you, I'll never need them. I just cant stand to throw things away.
/ Spindle
I definitely appreciate the offer, my kubota B6100 doesn’t have a mower deck, I have wanted one for years, less than a month ago we got serious, found a seller, got lots of pictures, drive from fl to N North Carolina only to find out that the seller didn’t have all that he claimed he had.
Hundreds of dollars in fuel, wear and tear on our vehicle and the two of us.
Beware, we live in a new world, a world where people like yourself ( that are kind and want to help people) don’t fit in.
Anyway we ended up buying a couple of power king tractors.
They are very well built machines compared to the garbage being made today.
Still extremely sloppy with low standards when manufactured but very high standards compared to today’s standards.
I’ll never get rid of either of my Kubotas though
/ Spindle #6
Have replaced bearing in a couple of JD spindle's in 2 different mower decks.... JUst break it down, get number off bearing and order new bearings and reassemble.... But these were sealed ball bearings and not tapered bearings...
/ Spindle #7
Have no clue about the spindles in general but...If you rebuild them with new bearings and I presume new grease seals and the replacement bearings come with seals, remove the inner seals on both bearings prior to installing them and make sure there is a grease fitting (or drill and tap in a grease fitting) on the spindle body where you can access it easily and fill the void in the spindle with good quality grease prior to installing the assembly back in the deck and on a reqular basis. Take your grease gun and replenish the grease in the spindle cavity until you can see grease oozing out of the bottom bearing seal.
Sealed beaings will die a slow death in any spindle where they aren't regularly greaseable. There is always a heavy load demand on mower spindles so the bearings require a constant supply of fresh grease and that don't happen with sealed bearings.
/ Spindle #8
Seems to me spindle wear is caused by improper greasing AND load. Load is controlled by the speed you cut the type of material being cut. For example tall Fescue cutting too fast without the proper RPM can cause excess stress on the spindles. The duller the blades the more load put on the spindles too.
I cut some red clover that is dying out earlier this week and that stuff is wiry. My JD felt like it was choking on it. I slowed it down and it cuts it much better. I also know its getting time to sharpen the blades. So I will do that this weekend so I can cut faster. I like holding off cutting the red clover until after it has reached seed bearing stage to replenish it for next season.
/ Spindle #9
They definitely do. I bet they change with deck size even on the same model tractor.
/ Spindle
Thankfully there are grease fittings already there
/ Spindle #11
Just inspect the bearings to make sure that the grease seals are only on one side. Typically, sealed bearings come with seals on both sides which work in non critical not heavy load applications but don't work in mower spindles at all.
If there are 2 seals, remove one and place the side with the removed seal inward (or upward on the lower bearing) and inward (downward on the upper bearing). Remove any old grease from the housing and pump in fresh grease (with the spindle fully assembled) until new grease starts to show out of the lower bearing. It will most likley show there first, before the top bearing, but the grease in the filled cavity will migrate up into the upper bearing during operation anyway. Just pump in grease into the spindle cavity on a regular basis, I grease mine about ever 20 mowing hours.
Nice thing about my Kubota front mount mower is Kubota installs angled grease fitting that can be greased easily from the upper deck so no underneath is required and the center blade spindle is actually an oil filled gearbox that requires no grease at all, just 90 weight gear oil.
My wife's ZTR requires the under deck greasing however.
If you keep them greased and you installed good quality bearings, they will last as long as the mower lasts.
Most manufacturers never remove the grease seals from the spindle bearings when new and that is what causes premature failure.
/ Spindle #12
Theres plenty of commercial grade ZTR mowers that dont have greasable spindles. Mine has almost 400hrs on it. Bought it used and hit things hard enough to stall the engine many times. Still have the original blades and spindles. However. I had a craftsman lawnmower that had greasable spindles and I had to stock a full set of spindles and blades every season because one rock and they shatter or bend.
/ Spindle #13
My Country Clipper has non-greasable, iron, rebuildable spindles. Don't know if the bearings are fully sealed or non-sealed and factory packed w/grease but at 578 hrs. of cutting they are still smooth as a baby's arse with the deck belt off. Any bearings that come sealed I usually carefully remove the seals and clean & regrease myself - have seen alot of sealed bearings with not enough grease from the manufacturer and/or grit left in from manufacturing - especially chinese bearings.
/ Spindle #14
My JD's have greasable spindles, BUT it's next to impossible to get grease gun to connect with the zerk... Maybe next set I rebuild I will put on angle zerks....
/ Spindle #15
Great point about why some spindles have issues while others don't. The diameter of the spindle has a big impact. A thicker spindle shaft doesn't flex as easily.
/ Spindle #16
I have rebuilt 3 spindles on Kubota mowers. They are not hard, but you will need a puller for the pulley and good quality snap ring pliers to remove the snap rings on the top and bottom of the spindle. You will also need to order two roller bearings and two oil (grease) seals for the spindle. I would advise that you also get a new blade attachment bolt. The last rebuild I did was two weeks ago and parts ran around $200 per spindle. You might be able to source the bearings locally and maybe save a few bucks, but everything else will have to come from Kubota.
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62130)
KNOW BEFORE YOU...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
New/Unused Landhonor Quick Attach Receiver Hitch (A61166)
New/Unused...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Freightliner Columbia (A63118)
Freightliner...
