Please explain this difference between diesel and gasoline engines
/ Please explain this difference between diesel and gasoline engines #141
This is the best overview of diesel systems I've ever heard. Guy is a Caterpillar-certified diesel tech.
/ Please explain this difference between diesel and gasoline engines #142
Not really. There’s no free lunch air compression energy. The only energy is from burning the diesel fuel, and diesels are inefficient at idle, because, unlike a gasoline engine that throttles air intake thus minimizing thermal and internal pumping losses, the diesel keeps pumping in full unrestricted volumes of cold air, and pumping it out the exhaust system. That’s why diesel’s don’t warm up well when started and idled. A high percentage of heat energy is wasted heating the unrestricted air. It’s essentially an air pump at idle
Cummins engines in RAM trucks during certain years do employ an electronically controlled throttle valve. When they fail in the closed condition lets just say drivability goes out the window.
Never heard of engine cloaking, have heard of coking. Tear down some hi mile engines, and gas or diesel it is amazing how Clogged up they can get. We had a Crown Vic that was so full of the EGR crap it was easier to replace the intake manifold with a new one than clean it. Same working on a 3.0 ecodiesel the egr had really narrowed the intake ports with all of the soot.
/ Please explain this difference between diesel and gasoline engines #143
Here is a video showing the exact problem with the intake valve sticking shut. In this case looks like no compression.
/ Please explain this difference between diesel and gasoline engines #144
I didn’t read the posts but I’ll give you my explanation on gas verses diesel.
A gasoline engine works with a constant cylinder volume decreasing pressure combustion process while a diesel is constant pressure increasing volume process.
A gasoline engine takes in a fixed volume of fuel & air that does not change during combustion cycle. It is compressed ignited and peak cylinder pressure occurs after ignition near top dead center (tdc) where there is very little mechanical advantage because of the rod crankshaft relationship. As the piston goes down the cylinder the mechanical leverage increases but the cylinder pressure is also dropping so torque quickly drops off.
A diesel on the other hand takes in excess air and compresses it to very high pressures causing the air temperature to increase to the point that when diesel fuel is injected it spontaneously ignites. As the piston is pushed down the cylinder fuel continues to be injected increasing the volume and maintaining combustion pressure. Fuel continues to be injected as the rod/crankshaft approaches the point of greatest leverage. But we’re still not done here. Fuel can continue to be injected maintaining pressure on the piston until past the point of maximum leverage and the available oxygen is used up.
That’s why diesels make so much more torque and pull so hard and feel like they don’t want to quit. Diesels produce increased amounts of torque thru more degrees of crankshaft rotation than gasoline engines.
Diesels take advantage of the mechanical leverage where (gas jobs) just peter out.
Hope this helps.
90cummins
I have not yet. Many answers did not address the question. Others tried to justify incorrect statements or had faulty logic. Like applying conditions to a diesel engine but ignoring the fact that a gasoline engine would have the same conditions. I guess I'm gonna need to really learn how the two different types of engines work and then post my findings. It looks like the library is in my future. Or I could get Chat GPT to write me some BS that I could then post here. Strike that. I'm heading to the library.
Eric
During the intake and compression of a gas engine the atomized intake mixture evaporates cooling everything it touches; valves, piston, and the combustion chamber. A leaner charge means less cooling. Further, when the burn happens it burns slower and doesnt complete before the ex valve opens. This causes some pretty hot spots! Diesel burn is controlled by metering the fuel into the burn, avoiding this effect.
/ Please explain this difference between diesel and gasoline engines #145
/ Please explain this difference between diesel and gasoline engines #146
I know someone here can help me with this question. Maybe the question should be spark ignition versus compression ignition, but I will just use gasoline spark ignition vs diesel compression ignition. Anyway, gasoline engines are very sensitive to air/fuel ratios. For example, gasoline engines when run too lean can run way too hot and this can result in pre-ignition, burnt valves, and melted pistons. I have personal experience with a melted piston crown, darn it. So the air/fuel mixture is closely controlled. Diesel engines don't control the air at all, the engines are always sucking in as much air as possible. This means that the air/fuel mixture is all over the place. So why is it that a compression ignition diesel engine can tolerate the very lean condition at low throttle settings? And, from what I have read here, diesel engines run hotter at higher throttle settings and running them at too low of a throttle setting, such as excessive idling, can cause problems such as "wet stacking". The reason being that the engine is running too cool and all the fuel is not burning completely. It's just idle curiosity on my part and I figure a good answer is likely to be found here.
Thanks,
Eric
The original diesel engines were developed to run on nearly anything as an oil based fuel. Mr. Diesel wanted farmers around the world to be independent of the supply chain. With the world wars, diesel was the option of choice for engines as fuel could be made from a vast amount of resources locally, not needing refineries like gasoline.
Diesel engines on average have about 200 to 300 less engine parts compared to a gasoline engine from the early days up to the mid-1980s.
Diesel engines pre-1990 are simple to work on.
/ Please explain this difference between diesel and gasoline engines #147
This is an entertaining thread that brings back many memories of the years gone bye.
Anyone remember Smokey Yunick?
He wanted higher compression engines that would run at much higher temperatures (Materials yet to be developed)
How about
Squish bands
Hemi Heads
Pent roof pistons
Schnuerle loop porting
Stratified induction
Tuned port induction
Ported and polished
Tuned headers
Tuned pipes
Resonance chambers
Two spark plug heads
Heron heads
Scavenging
the list goes on...and on.
Mostly to tame the uncontrolled flame fronts of "volatile fuels" like gasoline.
The oil burners rely on compression of the induction air to do all of the things mentioned above to gain PERFORMANCE. While many other methods and configurations assist with convenience.
The difference is the fuel burn characteristics.!!
One needs to get deep into fuel octane, aromatic hydrocarbons, vaporization, stoichiometry, flame propagation, Radicals,
Brake Mean Effective Pressure,Volumetric Efficiency, (it can be greater than unity for a well designed engine!)
My bet is.....
That the real difference between the most modern Otto cycle engine, and most modern Diesel cycle engines is getting more difficult to describe every day.
I can sum up with this.
Diesel engines usually have recessed piston crowns, while gasoline engines usually have flat topped or domed piston crowns.
There! That should simplify things! '-)
Great thread by the way!
/ Please explain this difference between diesel and gasoline engines #149
Sure, If one ignores the fact that the accepted measured value of the fuel used, is volume, and a gallon of diesel fuel has 14% more BTU’s and weighs 16% more.
When one accounts for efficiency vs mass of fuel consumed, instead of volume, the efficiency line advantage of compression ignition diesel engines starts to blur when compared to recent design direct injection gasoline engines.
/ Please explain this difference between diesel and gasoline engines #150
John Deere Z997R (A60462)
John Deere Z997R...
154 (A52708)
154 (A52708)
BRAD CO. TRENCHER (A60736)
BRAD CO. TRENCHER...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Giyi Mini QA Auger (A60463)
Giyi Mini QA Auger...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
