California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,641
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
I fabricated a removable mount to use the HF Tailgate Unloader on my 4x8 trailer. All its mounting hardware assumes an ordinary pickup tailgate so it doesn't match the blunt end of a trailer at all.I spent a while trying things, puzzling how to resolve the issue illustrated in several YouTube videos: A trailer tailgate isn't suitable for the unloder same as a pickup's tailgate. This unloader can only replace the tailgate, it can't be mounted with the trailer's tailgate in place.
Bringing home gravel with no tailgate would be a traffic safety issue and would likely cost me a ticket.
The best (only) solution I've come up with is - a temporary mount for the unloader that installs with the same downward pins as the tailgate. These pins go down into the rear of the frame rails.
Then to use the unloader - before loading gravel on top of the fabric, unspool the excess fabric out the back onto the ground, set the tailgate in place, then loop this excess fabric and its axle up over the tailgate and carry it on top of the gravel on the way home.
At home, lift the taigate out and set the axle with spooled excess fabric where the tailgate was.
This would need a mount with two big pins facing down, same as how the tailgate attaches now. Fabricating that 'artificial tailgate' mount should be simple. It would be similar to the trailer adapters others have in their YouTube videos, except removable.
Anybody have other alternatives?
I welded up a replica of the bottom edge of the existing tailgate, which mounts by dropping pins into holes in the frame rails.
The bearings for the fabric shaft are now two inches beyond the back of the trailer, spaced by 2x2 heavy gauge box tubing. This spacing is needed for the diameter of the rolled fabric.
The unloader fabric is sufficiently long to carry it home from the quarry looped up over top of the mounted tailgate, and down inside the trailer. Then at home swap them.
Next step is to weld a 3/8 drive socket into the opposite end of the fabric shaft to rotate it with a cordless drill - when its not under a lot of tension. Because it feels like hundreds of turns of the long crank handle to wind in the whole length of the fabric.
Note to others interested in doing this: the width of the fabric plus the axle bearings is considerably greater than 48 inches so this won't mount inside a trailer that is only 4x8. And fabricating something removable to mount the fabric axle beyond the end of the trailer isn't trivial. So this isn't a simple project. I almost returned the kit after a long time puzzling over how to mount it.
I'll post some photos when its complete.
