Front PTO / 3 point hitch installation
/ Front PTO / 3 point hitch installation #1
mtnman3321
Member
New Holland TV145
has anyone added a Zuidberg front PTO and 3 point hitch system?
how much did it cost for labor to install?
/ Front PTO / 3 point hitch installation #2
Those are not very common in the US, specially in the smaller tractors, so I don't think you'll get any answers.
Around here, I believe it's about €2000 to €2500 for a front 3pt + PTO on a compact tractor.
/ Front PTO / 3 point hitch installation #3
Double that for the parts kit?
/ Front PTO / 3 point hitch installation #4
That was with the kit installed and ready to work. It was a couple of years ago when I checked that too, so that most likely changed.
/ Front PTO / 3 point hitch installation #5
Only 'domestically' sold unit I know of with a front PTO and 3PH is a JCB Fastrak. Not a compact tractor either. They have 4 wheel independent suspension as well. and I believe a 45-50 mph ground speed.
Fendt might have one here as well.
/ Front PTO / 3 point hitch installation #6
I've looked at this over the years for my Hurlimann.
Just because they are produced for "small tractors"
I never have seen one in person, and don't know how the front pto would be fitted.
It's easy for me just to stick with the Allied front loader ;-)
But there are times when a front snow blower or sweep broom would come in handy.
I'm looking to put on a kubota, deere or NH in the 100-150hp range
/ Front PTO / 3 point hitch installation #8
It appears they are offered in many capacities. 3500kg, that quite a lift .
/ Front PTO / 3 point hitch installation #10
I could be wrong, but I believe that Lesnik doesn't actually offer a front PTO to go with the 3pt hitch.
from the on-line literature, I would agree. No US of A dealers that I can tell either. Product of Slovenia.
One of these could be a flexible option.
Zuidberg makes a front PTO and 3 point kit. I know the parts cost however I was trying to get a idea of the labor cost to install it.
/ Front PTO / 3 point hitch installation #12
thanks
/ Front PTO / 3 point hitch installation #13
hey did you get a front PTO? I just got an M5–111 and have a TON of woods to clean up. I do not own a SS and can't imagine how much more difficult, a flail mower or bush hog or forestry mulcher will be in reverse hour after hour after hour. Zuidberg front PTO looks solid- and theycompany makes OEM parts for leading mfgs. did you get it?
/ Front PTO / 3 point hitch installation #14
I just happened to see this today in "tractorhouse northeast"
It seems like a good price without doing any homework. 👍
/ Front PTO / 3 point hitch installation #15
Just incase you're interested.
There's no state mentioned but this has a phone number.
/ Front PTO / 3 point hitch installation #16
I just happened to see this today in "tractorhouse northeast"View attachment 4196691
That's surely less than an equal year Grand L would go for around here. Crazy. Are the prices on compact tractors that bad, or is it the depreciation of larger machines?
/ Front PTO / 3 point hitch installation #17
I really can only guess. That's a small utility tractor for the majority of farms and a loader would be a more common attachment for the front.
I actually found quite a few front pto/3pt in this issue. As usual the bigger Deere and Fendt $250k used machines, then quite a few 4000 series JD that appear to be Canadian residential snow blowing machines that have been traded. Probably from a bigger contractor rolling his fleet over. Some had a blower included on the front. At least in the picture.
I'd love to have that tractor, but it would have to have a loader as well.
/ Front PTO / 3 point hitch installation #18
The price on that M5-111 is pretty sharp. A new cabbed 4wd L6060 is $54K, whereas a cabbed 4wd M5-111 is $79K. I suspect that the M5-111 that @Rustyiron posted will not last long. Compact tractors also hold their value very well.
/ Front PTO / 3 point hitch installation #20
^^^^ this thread started back in May and sounded like the op was putting together a tractor with a front 3pt & pto.
My posts were simply showing a tractor currently for sale with one.
I'd love one myself one day.👍
Hopefully he'll follow up if he finds one.
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
UNUSED MINI EXCAVATOR (A64281)
UNUSED MINI...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2025 Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
2002 John Deere 544H Articulated Wheel Loader (A61572)
2002 John Deere...
PENDING SELLER CONFIRMATIONS (A59914)
PENDING SELLER...
