Front PTO / 3 point hitch installation
/ Front PTO / 3 point hitch installation #1
mtnman3321
Member
New Holland TV145
has anyone added a Zuidberg front PTO and 3 point hitch system?
how much did it cost for labor to install?
/ Front PTO / 3 point hitch installation #2
Those are not very common in the US, specially in the smaller tractors, so I don't think you'll get any answers.
Around here, I believe it's about €2000 to €2500 for a front 3pt + PTO on a compact tractor.
/ Front PTO / 3 point hitch installation #3
Double that for the parts kit?
/ Front PTO / 3 point hitch installation #4
That was with the kit installed and ready to work. It was a couple of years ago when I checked that too, so that most likely changed.
/ Front PTO / 3 point hitch installation #5
Only 'domestically' sold unit I know of with a front PTO and 3PH is a JCB Fastrak. Not a compact tractor either. They have 4 wheel independent suspension as well. and I believe a 45-50 mph ground speed.
Fendt might have one here as well.
/ Front PTO / 3 point hitch installation #6
I've looked at this over the years for my Hurlimann.
Just because they are produced for "small tractors"
I never have seen one in person, and don't know how the front pto would be fitted.
It's easy for me just to stick with the Allied front loader ;-)
But there are times when a front snow blower or sweep broom would come in handy.
I'm looking to put on a kubota, deere or NH in the 100-150hp range
/ Front PTO / 3 point hitch installation #8
It appears they are offered in many capacities. 3500kg, that quite a lift .
/ Front PTO / 3 point hitch installation #10
I could be wrong, but I believe that Lesnik doesn't actually offer a front PTO to go with the 3pt hitch.
from the on-line literature, I would agree. No US of A dealers that I can tell either. Product of Slovenia.
One of these could be a flexible option.
Zuidberg makes a front PTO and 3 point kit. I know the parts cost however I was trying to get a idea of the labor cost to install it.
/ Front PTO / 3 point hitch installation #12
thanks
/ Front PTO / 3 point hitch installation #13
hey did you get a front PTO? I just got an M5–111 and have a TON of woods to clean up. I do not own a SS and can't imagine how much more difficult, a flail mower or bush hog or forestry mulcher will be in reverse hour after hour after hour. Zuidberg front PTO looks solid- and theycompany makes OEM parts for leading mfgs. did you get it?
/ Front PTO / 3 point hitch installation #14
I just happened to see this today in "tractorhouse northeast"
It seems like a good price without doing any homework. 👍
/ Front PTO / 3 point hitch installation #15
Just incase you're interested.
There's no state mentioned but this has a phone number.
/ Front PTO / 3 point hitch installation #16
I just happened to see this today in "tractorhouse northeast"View attachment 4196691
That's surely less than an equal year Grand L would go for around here. Crazy. Are the prices on compact tractors that bad, or is it the depreciation of larger machines?
/ Front PTO / 3 point hitch installation #17
I really can only guess. That's a small utility tractor for the majority of farms and a loader would be a more common attachment for the front.
I actually found quite a few front pto/3pt in this issue. As usual the bigger Deere and Fendt $250k used machines, then quite a few 4000 series JD that appear to be Canadian residential snow blowing machines that have been traded. Probably from a bigger contractor rolling his fleet over. Some had a blower included on the front. At least in the picture.
I'd love to have that tractor, but it would have to have a loader as well.
/ Front PTO / 3 point hitch installation #18
The price on that M5-111 is pretty sharp. A new cabbed 4wd L6060 is $54K, whereas a cabbed 4wd M5-111 is $79K. I suspect that the M5-111 that @Rustyiron posted will not last long. Compact tractors also hold their value very well.
/ Front PTO / 3 point hitch installation #20
^^^^ this thread started back in May and sounded like the op was putting together a tractor with a front 3pt & pto.
My posts were simply showing a tractor currently for sale with one.
I'd love one myself one day.👍
Hopefully he'll follow up if he finds one.
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
1995 Ford LT9000 Tri-Axle Dump Truck (A61573)
1995 Ford LT9000...
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
2019 International DuraStar 4300 26ft. Reefer Box Truck (A61573)
2019 International...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61573)
2020 Mack Anthem...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
