Life on the farm
   / Life on the farm #961
I wouldn't say well, but yes, they did pay to mess up the farm. But, so far think they are doing a pretty good job on their method.
Nice photo! Any idea why they picked the route that they did? Also, is the pipe on perpendicular supports in the lower part of the photo, and if so any idea why?
All the best,
Peter
   / Life on the farm
that's a frame worthy photo. If you edited out the field office upper left.
there's 2 field offices there, wind blew one over last week LOL
Daytime version, minus the office. pics get blurry when I zoom in.
   / Life on the farm
All the best,
Peter
That was our 2nd route suggestion to them. They proposed the orange line route, which put it a lot closer to our house, and crosses our water line from our water well. This would have avoided the deep hill in purple. I first proposed the blue line along the edge of our property. Their next proposal was a hybrid of this, where they drew the line right thru the middle of our water well (pink line.).... Two water wells are yellow circles and light blue is water line to our house. We settled on the final route, although they did slide it up into the field a little further than what we agreed upon. Purple areas are butt puckering to mow. Dad used to mow them years ago, but we let them grow up. In the 3 years or so that we haven't had cows, it's amazing how much has grown up.
In hindsight, final route was a better route than along the property line. At one time, when they didn't want to agree to some terms, we flat out told them to go around us, and they caved. More than anything, they needed the flat road and the work area at the end of our field in order to work the property next door. If they had went around, they had no easy way to take the pipe across them. The hills don't look steep in the pictures, but they are.
Next picture is to the north of us. Pics taken the same day, but with the angle, you can't even see the line north of us in the first picture.
North of us crosses a very steep valley. Train track ran up this valley until 1932, shown in orange, and there is an old tunnel down there (orange circle). There was a one room school down along the tracks, my Great uncle went there. He would have walked from the property south of us, down over that hill somewhere to get to it. This was my playground growing up, as well as the other side of our farm which is now a park. the purple circle is where my brother flew his drone from to take this pic.
   / Life on the farm
All the best,
Peter
forgot to mention, but it looks like they placed the pipe on sand bags, no doubt to be able to weld the joints. It appears they are keeping the sand bags under the pipe. I have not been there in a week and a half, and they already have the pipe in, welded, and covering since then. Lots of people working there. Dont' know where they come from, where they stay, but some of them are there about 12 hrs a day. every morning they seem to have a meeting where this camera is aimed, and usually a dozen or more trucks, plus side by sides they use. In addition the water line people have been coming and going a lot also, here is the water tank down in the valley, that they will fill from the creek, and pump up across our land.
   / Life on the farm #965
Thanks for the explanations!
Sand bags to facilitate welding makes complete sense.
All the best, Peter
   / Life on the farm #966
Now you've got me curious. Are they using metal pipe or hdpe for the water? Either way the welding or fusion is normally done above grade, then the completed sections are placed in the trench using side booms.
Edit. I backtracked on your posts to the delivery of pipe pic. It's coated metal pipe. I woulda thunk that was for the gas line. Hmmm, unless there's high oxide or rock content there.
   / Life on the farm
Now you've got me curious. Are they using metal pipe or hdpe for the water? Either way the welding or fusion is normally done above grade, the the completed sections are placed in the trench.
two different pipelines to two different pads by two different companies. oil/gas pipeline is metal and permanent.
separate water pipeline is 1 yr above ground easement, is some HDPE, some softsided pipe that came on reels.
The HDPE they fused behind our barn, then used a dozer to pull it to the back of our farm. It's used to go down the steep hill to the creek. At our farm, they transition to other pipe.
This is at our back property line where they will transition. They chained the HDPE to some trees to keep it from sliding down the hill in places.
This is down below our pond.
when they brought the HDPE pipe in, they had to pull the back of the trailer sideways in order to back it in, and they still managed to take down the electric warning poles.
The fusing equipment was on a tracked vehicle, but I didn't get a picture. I was there the day they loaded it in a trailer to take it away. I have a set to fuse small HDPE pipe, up to 2" I think. This a little beyond my ability. lol
When they pulled the long snake back thru our field, they wiped out about some fencing with it. Will wait and see if they fix it. The guy that we let hunt on us has a game camera there, I need to ask if he has a good pic of them pulling it back.
   / Life on the farm
They just took that dozer away today, used it to pull the back end of the truck around.
   / Life on the farm #970
Thanks for the update. Makes more sense now.
Ya think they'd have jumped up the height of the wires rather than keep paying to put them back up. But, that's all incidental I guess.
   / Life on the farm
They only broke the wire once. They hit it a few other times. They broke the pole on the far end near the corn crib. They tore down the warning flags several times. We took down the electric to the garage, they could never get under it. It was only powering one of my cameras.
Not sure the year dad installed power to the well, etc. early pics of our old house shows a large water tank next to the side porch, fed from roof.
He did say he bought the wire from Sears catalog.
The first water line from the well was galvanized pipe. That was replaced with black plastic sometime in mid to late 70s. Have not found pics of dad running backhoe to dig for it, I remember there being a picture somewhere. What I been referring to as the barn by the house was originally a chicken house.
   / Life on the farm #972
Is the surface water line to provide water for their construction, or is it routing around a water line that they need to disturb as part of laying the new gas line? Or something else entirely?
   / Life on the farm
to be used on the well pad.
   / Life on the farm
More equipment leaving. The pipe is buried all the way across our farm, and yesterday they dug across the road to lay the pipe across it. They will come back to do the steep hill on the property to our north, as they ended just past our line, and before the big valley.
   / Life on the farm
This is the tank down below our farm, that the water will get pumped from.
Water line goes up the hill somewhere in these woods to get to our farm, which is above the red line.
   / Life on the farm
pipeline is covered to the pile of pipes, from here it will take a sharp right turn down the hill. pics a bit blurry as they are clipped from a drone video.
   / Life on the farm #979
Does Dad hire out? (Actually, I have a new hero in your Dad!)
I can think of nothing more enjoyable, or more fulfilling than being able to be on a tractor, mowing my own land at 101!
   / Life on the farm
I suspect just to see if he still could. He hasn’t been on tractor in about a year, since he mowed some last May or June. At least he was just on the flat near the house.
Sellick S80 (A60462)
KSI Conveyor (A56438)
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
2012 Dixie Chopper Magnum 2460 60in Zero Turn Commercial Mower (A59228)
2012 Dixie Chopper...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
1985 John Deere 540B Skidder (A56438)
1985 John Deere...
