Kubota brake safety switch
/ Kubota brake safety switch #1
Mike1955
Kubota
On a zg222 it looks really difficult to change this brake safety switch. Anybody have any tips? Thanks in advance
/ Kubota brake safety switch #2
Yeah, I’ve tackled that on a ZG222, trick is to remove the seat and rear fender for better access, then use a stubby screwdriver to reach the tight mounting screws. Patience and good lighting make all the difference!
/ Kubota brake safety switch #3
Hire a contortionist with small hands
Thank you Kestrelrogers. I gave up. I left it where it was, cut the two wires and bought another limit switch. I mounted it where it would work from the thing that hit the other one. I works good. It has to be released or the mower will go dead.
I defeat all those switches, A paper clip is your best friend.
This one cannot be defeated. Has to close to start the engine the open to continue running.
/ Kubota brake safety switch #7
My JD tractor seats now has 3 wires & can’t be tricked like the old 2 wire safety switches :mad:
My KTM kickstand switch is the same 3 wire setup too.
300 GALLON FUEL TANK (A62131)
300 GALLON FUEL...
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
iDrive TDS-2010H...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
Genie Z60 Articulated Boom Lift (A64047)
Genie Z60...
1761 (A58375)
1761 (A58375)
