Massey GC2300 Top Link lenght
/ Massey GC2300 Top Link lenght #1
RobbyB
Member
GC2300
Does anyone know the correct top link length for a Massey GC2300? I need to replace a missing one on my tractor. Thank you in advance for your help.
/ Massey GC2300 Top Link lenght #2
The stock adjustable top link on my 2022 GC 1723EB is about 14-1/2" long at its shortest to maybe 22" at its longest.
Looking at my 2008 GC2300 the distance from the 3pt hitch to the top link tractor mount is 18" center to center. Does this sound right?
I can find top links that have center to center lengths from 17.5 to 26 or 28" or shorter ones with 13.5 - 20 inches. Which one would be better, ones that can be adjusted shorter or ones that can be adjusted longer
I should mention that I mainly will use this for a ballast box attachment but also will consider a York rake in the future. I am assuming I want the shorter top link so I can adjust the ballast box slightly forward for better ground clearance when loading on trailer of hilly surfaces. But would I need the longer one so I have more down pressure for the York rake?
/ Massey GC2300 Top Link lenght #6
I am using an hydraulic top link cylinder from agristoreusa.com: #37299 $289.99 14-3/16 > 18-1/2" on my GC1723EB and it works pretty well. But I wouldn't mind one slightly longer.
Thanks. I will go with the 13.5 to 20"
2015 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2015 FREIGHTLINER...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
12 Ton Hydraulic Bottle Jack (A61567)
12 Ton Hydraulic...
New/Unused Landhonor Adjustable Gantry Crane (A61166)
New/Unused...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
