LS Tractor Won't Start After Hooking Up Bush Hog
/ LS Tractor Won't Start After Hooking Up Bush Hog #61
My Kubota L4330HST did not start last week after hooking up equipment.
No click. No error on digital dash.
I Checked the usual things:
Checked safety switches ( seat switch, gear selector, clutch pedal switch, HST pedal, PTO switch).
Battery voltage. OK.
Cleaned battery terminals.
Checked fuses. All OK.
The Kubota has a power cable to the starter and a single wire to the solenoid to start.
A multimeter showed power to the starter cable AND the post on the starter.
When I went to check voltage to the solenoid wire I found that it was loose.
It is a push on spade connector. Testing it showed voltage when trying to start.
The solenoid wire had vibrated loose.
Problem solved.
/ LS Tractor Won't Start After Hooking Up Bush Hog #62
Glad you are back in business. I always check the simple things first. A learning experience.
/ LS Tractor Won't Start After Hooking Up Bush Hog #63
Not sure what to do here, hooked up the LS brush hog and when I turn the key it does nothing.
Brake is on. PTO switch is off. Ran fine when I boxed the road, went to bush hog and this is where I am stuck.
Anybody know what went wrong, or what it could be?
Try a bit of wd 40 on the spring at the engine end of the PTO switch cable. Just a guess as I got caught the same way. The spring returns the PTO to disengaged. It gets dirt rust or whatever and does not return properly.
/ LS Tractor Won't Start After Hooking Up Bush Hog #64
Here's my "two cents worth" -- obviously -- "something changed"!
IF it was working fine when you box bladed your drive and the only difference is hooking up to your Bush Hog and now you can't get it running and have tried everything safety switch wise with no luck -- disconnect the Bush Hog and start over.
I ALWAYS go back to the last thing done/happened/changed etc. to correct an issue.
/ LS Tractor Won't Start After Hooking Up Bush Hog #65
Remove starter and use sand paper and sand the mating surface of the starter and mounting surface, for a good ground. Also while you have the starter out, see if it turns over OK with jumper cables.
/ LS Tractor Won't Start After Hooking Up Bush Hog #66
Problems with cranking:
First try to crank with the headlights on and a helper. If the headlights dim when you try to crank, there is a battery or ground issue. Make sure the battery is in good condition, and the ground and power cable to the starter are good.
Second, check the solenoid it self. there is a copper disc on some of them which makes the actual contact. It is supposed to rotate, every time the solenoid engages. The fact that you try to crank many times, and then it started several, means it could have rotated to the clean spot, and made good contact, and has now moved to the bad sector.
Third things can be bad internally with the starter motor. I had a truck which intermittently would start, or not with no real pattern. Turned out to be one broken wire on the commutator. Depending on where the motor came to rest, and whether the brushes were on that sector of the commutator, it would either start or not. Got it resoldered on, and worked just fine for years until I sold the truck.
/ LS Tractor Won't Start After Hooking Up Bush Hog #67
If you hear a click when you turn the key, clean the battery terminals and cable ends. Check the ground cable from the battery to the chassis. Make sure it is seurely connected. Measure the continuity of the battery cables (while disconnected from the battery from battery connector to where it connects. Sometrimes the cable will corrode away under the outer rubber jacket and not have enough actual wire to carry the current needed to drive the starter.
I recently had a similar issue and it turned out to be the ground cable to battery terminal was just bit loose on the battery. I cleaned the terminal and connector, reinstalled it, and the tractor started right off.
New developments:
I was finishing up mowing one of my fields, when I heard a loud clang on the bush mower, looked back, and the shaft cover had moved away from the gear box, and the mower was wobbling pretty badly. I hit absolutely nothing but grass.
So anyhow I shut off the mower and parked it.
Went back out to lift the mower (had a call from work) so I could look under it. Had to tap the starter again to get it to start.
When I went to lower the deck (3 point) it would not lower.
Gotta say things are getting frustrating. I have 24 hours on this rig.
/ LS Tractor Won't Start After Hooking Up Bush Hog #70
New developments:
Check drop control knob below the seat. Now if you are like me something is jammed into linkage or or 3 point arms. I'm not gentle with the brush hog and no flat mowing, just real brush, rocks and what ever else I find :rolleyes:
Thanks, I'll go check that out.
That did the trick.
As heavy as that bush mower is, you'd think it would drop easily.
I'll go out and check the connections after she cools off or perhaps tomorrow.
Here is another piece to this: it only clicks and won't start after it is hot from running. Does that mean anything else?
/ LS Tractor Won't Start After Hooking Up Bush Hog #74
This many problems at 24 hours, I'd be finding a way to return the whole package. Seriously.
In all the half-dozen plus tractors I've owned, I've only ever had one in-warranty failure, a seal that blew out in my 3033r. It was diagnosed to be an assembly issue, and the dealer had it fixed within one business day.
Returning the whole package isn't a viable option at this point.
The 3 point not dropping was figured out thanks to @Eagle1 reminding me of the drop control knob.
At this point I haven't determined if the starter connections are the issue. Someone else said they had the same problems and found these connections were loose.
My concern now is the connections to the starter, whether they are loose or not, and why after the tractor has warmed up it doesn't want to turn over, and only clicks when the key is turned. Once I get more time, I'll get a chance to check everything. My work schedule is all over the place, and I don't know day to day where I will be.
Reviews on this LS are really good, so I'm wondering if I got a unit with a bad starter or another issue. If so, that would make my ownership experience a one in warranty failure as well.
/ LS Tractor Won't Start After Hooking Up Bush Hog #76
Maybe I missed it. What size and type LS Tractor is this?
/ LS Tractor Won't Start After Hooking Up Bush Hog #78
I see there are a number of service manuals available for purchase. Some are free but I do not know what systems they share with your unit.
/ LS Tractor Won't Start After Hooking Up Bush Hog #79
I had taken the mention of something breaking on the mower yesterday as part of the tractor package, as well. But maybe that was unfair.
Hopefully it's just a loose wiring connection somewhere in the system, but your mention of it being pretty consistent only after warmed up makes me think it might be more likely a cracked wire in a potted coil assembly (solenoid).
You'd expect loose wiring connection issues to be more random prior to eventual complete and permanent failure. Usually when you see something that fails to actuate only when warm (or only when cold), it's in a potted assembly or circuit board, where CTE is causing a connection to make or break with temperature.
/ LS Tractor Won't Start After Hooking Up Bush Hog #80
Could just be a sticky brush, that is keeping it from contacting the armature fully once warm or the contacts in the solenoid sticky when hot. I had a shut off solenoid not pulling in on cold days because a bit of moisture internally that would freeze on my Kubota. Had a little tear in a gasket only showed up when well below freezing...
Once I figured out the quirks on the LS (differences from Kubota) it has been a joy and trouble free other than abuse by me.
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2019 GALLEGOS TRAILER PNEUMATIC TRAILER (A60736)
2019 GALLEGOS...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2020 PETERBILT 567 DAYCAB (A60736)
2020 PETERBILT 567...
