Barbed wire vs Flail
/ Barbed wire vs Flail #21
Got the pulley to come off. No lube needed. It would have taken a lot longer without all of the help. Never used a taper lock before.
Hello Torvy,
Please be sure to use a torque wrench for the taper lock screws and
a bead of blue Loctite on the taper lock screw threads to secure the
taper lock bushing.
/ Barbed wire vs Flail #22
I bought a used tiller that had been used one time and the guy wrapped it full of heavy fence wire, it was wound so tight it was a nightmare. I took the acetylene torch to it and made quick work of it.
Thanks all. Using @leonz idea, I was able to get it off of there. Since it's a ditch mower, setting it on its back was tricky.
It's all put back together. Lube and testing will have to wait until tomorrow. The beauty of retirement. I can stop before I hurt myself and do more work tomorrow.
I thought about using the dremel, but I'm out of the grinder wheels. Hopefully there won't be a next time.
Leonz needs a dedicated title on here of Flail Master.
  • Good Post
Reactions: D&D
Just enough here to stop rotation. It's free now.
/ Barbed wire vs Flail #25
It always amazes me how much junk is left in the fields. I boarded horses and mules on two different places and both had piles of junk lying around, just waiting to nick up the horse's legs.
In 2006, I bought 20 acres that had been pasture for cows and there was old fencing left behind everywhere, covered up in the grass. I THINK I've removed all of it. At least I HOPE I've removed all of it.
/ Barbed wire vs Flail #26
Sometime ago, I caught a decent length of fencing net with my cutter. While it looks bad, since I run chains and not blades, it was a matter of finding one end of the fencing and just uncoil it.
I've also completely destroyed an old cast iron stove hiding in the brush with this cutter.
(fat finger in the way)
I ended up testing it yesterday anyway. Weather showed rain today. Turned out we got some in the evening. A couple of drops while I was wrapping up.
Worked like a champ. Now I can hopefully walk around without so many ticks joining me.
/ Barbed wire vs Flail #28
That is great to hear Torvy, happy mowing.
/ Barbed wire vs Flail #29
We had several days of 20 degree temps in middle TN, but it didn't seem to reduce the tick population.
/ Barbed wire vs Flail #30
I suck up wire in my drum mulcher regularly. I carry a set of 10" bolt cutters from HF. Can usually cut it out pretty quick.
/ Barbed wire vs Flail #31
Several decades ago the county sheriff came to the saddle club asking for help rounding-up neglected horses running loose in an old junk yard.
He wanted us to rope them for transfer to a recovery place. we all declined, I wasn't about to endanger my roping horse that way.
Old wire is dangerous to animals and a big aggravation to me. I make an attempt to remove all old wire every time I patch a fence.
By law every junk yard is required to accept all types of wire, smooth, barbed, woven, welded, etc. Some don't like it and put up a fuss though.
That was my first move. Unfortunately, the placement was such that I couldn't get the jaws on that last little bit.
/ Barbed wire vs Flail #34
It seems like mowers have a magnet and just enjoy
getting tangled up it fencing wire
willy
/ Barbed wire vs Flail #35
The worst I’ve had is I was tilling out some weeds when I “discovered” a 20’ length on #3 rebar. Completely wrapped it around the shaft. About an hour with an angle grinder to remove.
(2) Pride of the Farm Waterers (A66408)
(2) Pride of the...
Rolling Cart Base (A65640)
Rolling Cart Base...
Case 222 Garden Tractor (A66408)
Case 222 Garden...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A65643)
2008 STOUGHTON...
30x57 Welding Table (A65640)
30x57 Welding...
2016 PITTS LB35 - 33CS LOWBOY TRAILER (A64277)
2016 PITTS LB35 -...
