Tc40 a fluid leak
/ Tc40 a fluid leak #1
Gfagel
Millersburg, Michigan
New holland tc40a
The shaft for the 4 wheel drive is leaking fluid at the rear of the tractor. The shaft is loose and I can slow down the leak by pushing the shaft back and or rotating it. I am wondering if there is a seal that I can replace. I am trying to find a diagram with part numbers so I can repair this issue.
Thanks in advance
Gary
/ Tc40 a fluid leak #2
/ Tc40 a fluid leak
Hi Gary,
You can govto Messicks, TC40, Transmission section, 4wd dropbox, pictured here. New Holland TC40 - 4 CYL COMPACT TRACTOR(01/98 - 12/05) Parts Diagrams
If you can wiggle the shaft, you have a bearing going out. Drain the oil, disconnect the 4wd driveshaft and drop the dropbox.
Thanks much will get the parts ordered and
Hi Gary,
thanks much appreciate the information. Will get the parts ordered and dive in
Gary
/ Tc40 a fluid leak #4
I have really slowed leakage to manageable on my tc40 by simply taking a pick and carefully cleaning the crud out of the seal.
I believe what your talking about is the rear of the front driveshaft? Check the exploded view for what parts and seals you may need and what's available before you dive head first into it.
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
2005 International School Bus (A64194)
2005 International...
28ft. TV Tower (A65640)
28ft. TV Tower...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
JOHN DEERE 220 - 18' DISC HARROW (A64277)
JOHN DEERE 220 -...
