Oil viscosity change for a 5.7 Hemi?
   / Oil viscosity change for a 5.7 Hemi? #31
Many Many moons ago when I lived in Wisconsin even when
the; temps went -35F I used 10W30 reg oil in all my vehicles
year round and never had any problem starting in the cold
mornings.
synthetic oil generally sticks to engine components better than conventional oil when the engine is off, offering superior engine protection. This is due to the superior film strength and stability of synthetic oil, meaning a greater amount of oil remains on the engine parts after the engine is shut down. This helps to reduce wear and tear on the engine during startup, when most wear occurs
willy
   / Oil viscosity change for a 5.7 Hemi? #32
mornings.
willy
Back in those days engines were much different. The clearances were not as tight and the valvetrains didn't rely as heavily on proper immediate oil pressure to function like modern variable valve timing, overhead cams, chain tensioners ect. Not to mention the need for modern turbo engines to have the correct weight oil for proper oil flow. Oil quality, weight and maintenance is easily the top contributor to modern engines lasting or not.
   / Oil viscosity change for a 5.7 Hemi? #33
If worried about oil on bearings and such, a '19 should have the option of holding the gas pedal to the floor during the normal starting procedure.
Doing that cuts the fuel off, so the engine turns but doesn't start. I give all our FCA/Stellantis vehicles a few seconds of letting the engine build pressure before starting them.
   / Oil viscosity change for a 5.7 Hemi? #34
The recall of the GM engine and the 'warranty' fix of going with a heavier weight oil got me thinking. I've got a '19 Ram 1500 with the 5.7 Hemi, 90K on it now and it calls for 5W-20 oil which I've always used. Seems as if one of the problems with this engine is flatspotting the roller lifters. I do an oil analysis every oil change and there's no wear or non to speak of nor particles in the filter.
What's the collective thoughts of going to a heavier oil say a 10W-30 or a 15W-40?. The lighter oils were supposedly spec'd for mileage which I find hard to believe oil viscosity will make a hill of beans difference on a warm engine. My concern is oil flow at lower temps. Summer's not so bad but winters get as low as -10C around here and I don't want to cause starvation issues. Even saying that, I would think there's more than enough residual oil left on an engine to lubricate it during a cold start until the oil starts flowing. Thoughts?
The Pennzoil Ultra Platinum 5W-30 is a 'lighter' 30w (lower end of the 30w viscosity scale) and is what I used to replace the 5W-20 recommended for my 2019 F-150 5.0. Not only did it quite it down some, I am getting better MPG and upped my 'avg' by .5 over the last 6 months or so without resetting it.
20w is just way to light for a working truck, IMO.
   / Oil viscosity change for a 5.7 Hemi? #35
Most of the Hemi cars, be it a Challenger, Charger, or 300 have a way to manually shift. The older ones had Autostick, you slap the shifter right or left to shift up and down. This keeps the MDS turned off. Going down the highway it’s not an issue but if you pull up to a stop sign it will try to hold 1st gear when you pull away. Full throttle it will upshift in autostick automatically but most people don’t drive that way.
It’s the same way with paddle shifters the newer models have. Use the paddles MDS is turned off.
I wish I still had the SRT8 to verify your info. Had to sell it as it needed 8" of ground clearance to get to our retirement home.
   / Oil viscosity change for a 5.7 Hemi? #36
I’m pretty much 100% positive using the autostick or paddle shifters turns MDS off. We have had 3 Chrysler 300 C and one challenger. Same with using tow haul in the trucks.
   / Oil viscosity change for a 5.7 Hemi? #37
That’s actually interesting. I’ve always viewed it totally opposite of this. I’ve always figured, the quicker and engine fires, and gets up to speed, the better. I’m pretty sure starter motor driven , crankshaft Rpm’s are slower than your minimum idle speed required for adequate oiling of the entire engine.
You’re still spinning all the components either way, if there’s no good oil on surfaces at a quick start, there’s the same, no good oil, while you’re slowly turning it over against compression, and valve lift.
I’m guessing the difference is negligible either way.
   / Oil viscosity change for a 5.7 Hemi? #38
A drill motor turning just 500 rpm will circulate a lot of oil when prelubing an engine.
Now that is using a distributor body or a drive tool
   / Oil viscosity change for a 5.7 Hemi? #39
Yeah, turning just the oil pump is one thing . That’s totally different than cranking an entire engine assembly with compression strokes using a starter motor.
I think people confuse the two.
   / Oil viscosity change for a 5.7 Hemi? #40
OK, to put it in a tractor content. With mechanical pressure gauges on tractors and trucks I have seen oil pressure on the gauge before they started while cranking.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
Rooster Weathervane (A59231)
Rooster...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
Kubota RTV-X1140...
