7' Tiller on a Smaller Tractor
/ 7' Tiller on a Smaller Tractor #1
Bert the Bard
RK25
I've inherited a 7' Tiller, but I have an RK25 tractor.
Would I be able to use this tiller if I removed 2 flanges on each side?
/ 7' Tiller on a Smaller Tractor #2
Sure!
Try just going slowly at full width!
But it's gonna be heavy. Until it's in the ground
/ 7' Tiller on a Smaller Tractor #4
Need a little more info. There are lots of kinds of tillers.
Is this a ground-driven or PTO driven tiller? Or hydraulic driven? All are common.
Is the tiller mounted as a front, mid, or rear type?
By "flanges" do you mean the digging tines??
Are the tines straight or curved?
Do the tines rotate in the same direction as the tractor tires or counter to it?
/ 7' Tiller on a Smaller Tractor #5
I wouldn't remove anything from it. If it's too big, sell it and buy the right size. You can find them used -- though this is NOT the best time of year to shop for used tillers. (It's a great time of year to sell yours though!)
I would think the perfect tiller for that tractor is 5'. You want the smallest tiller that will cover your rear wheel tracks. 6' would be pushing it, so you're about "2 sizes" too big, in my opinion.
/ 7' Tiller on a Smaller Tractor #6
I would think the perfect tiller for that tractor is 5'. You want to smallest tiller that will cover your rear wheel tracks. 6' would be pushing it, so you're about "2 sizes" too big, in my opinion.
Ditto. This is great advise.
Sell the tiller and buy one to fit the tractor and application.
The RK25 has small rear wheels too. 4FT or 5FT tiller would be ideal for the SCUT.
A 7ft rotary tiller goes for $3,500-ish new. Sell yours for 1/2 that price used. I bet it would go QUICK in a heart beat.
Then take the $1,750 from the sale and BUY a brand new one for $1,699 at Rural King where you bought the RK25.
/ 7' Tiller on a Smaller Tractor #7
Actually, the RK25 is pretty beefy. Much larger than the RK24. It's pretty much the same size as a Kubota B7800. Would handle a 5' tiller well size-wise. HP might be a little light but you have to crawl in low range and it should handle it.
PTO driven.
Rear mounted.
It has 11 flanges with curved digging tines.
Tines rotate in same direction as the tractor tires.
/ 7' Tiller on a Smaller Tractor #9
PTO driven.
Rear mounted.
The only reason not to test it is that you might need to change the pto shaft length.
/ 7' Tiller on a Smaller Tractor #11
You wouldn’t need the tiller to cover tracks if you space rows.
A 4’ tiller would make one pass between the tires
then space out your next row so the rear tire is just at the previously tilled row’s edge.
This also creates a work path between rows.
/ 7' Tiller on a Smaller Tractor #12
I think the RK25 PTO horsepower is 18? Should specify how much in your manual or on RK or TYM websites.
/ 7' Tiller on a Smaller Tractor #13
This is the same old debate, but would you ever actually go buy a tiller that was not as wide as your rear wheels???
When the average person tills their garden, they expect to see a seedbed of tilled ground from edge-to-edge. The entire area. Tilled up. Not with untilled paths in the middle. Anyone paying to have their garden tilled expects it to all be tilled and smooth with NO tire tracks or paths left.
If you want to leave untilled areas, you can certainly do that with a properly sized tiller. Just move over.
On the other hand, with a narrow tiller on a wider tractor, there is NO WAY to leave an entire area tilled with no tire tracks.
So how does it make sense NOT to have the tiller a little wider than your tires? Seems silly to suggest that it's handy to have a too-small tiller. Worse than too big.
/ 7' Tiller on a Smaller Tractor #14
NOT true, offset the tiller to cover one tire and go the same direction for each pass with the tiller covering the tire track on that side.
SR
/ 7' Tiller on a Smaller Tractor #15
believe the tail would wag the dog on this application. but never hurts to try.
attempting challenging tasks with under powered sub compacts is a common theme on this forum, good luck
/ 7' Tiller on a Smaller Tractor #16
Made sense for us where we planted bushes in rows and our harvest plantings were also in rows.
With pathways between beds, it made it much easier to access either side of the beds. All
we did was mow the grass paths between the planted rows and used these clippings that were blown onto the rows, as mulch. It also cut down on weeding. Worked out very nicely grasshopper.
Not everything planted necessitates a vast ,open expanse of tillage.
So that is one example where the tiller doesn’t have to be as wide as the tire track.
/ 7' Tiller on a Smaller Tractor #17
I have seen where even 3’ wide tillers have compromised some scuts depending on the soil type and texture.
It still is amazing to me what can be done with a scut. Many punch above their weight class.
/ 7' Tiller on a Smaller Tractor #20
It's going to take a bigger tractor to run that one.
SE
11 flanges.
6 tines per flange.
I agree with Rob and 84 " tiller with large 6 tine flanges will require more tractor, probably 40 pto hp as a minimum. Turning a tiller can load an engine down. If watch your temperature gauge over an hour you may overheat. That's with a 35 hp tractor and tiller.
I know nothing about your tractor but I recommend you get a tiller sized for your tractor. A 7' tiller is too big a scut.
2009 CHEVROLET IMPALA CAR (A66091)
2009 CHEVROLET...
Bigfoot with Bottle Metal Decorative Yard Art (A66738)
Bigfoot with...
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2016 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2016 GENERAC...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2019 CHEVROLET EXPRESS 2500 4X2 S/A CARGO VAN (A69167)
2019 CHEVROLET...
