KL4030C loader kickstands
/ KL4030C loader kickstands #1
tacticalturnip
Super Member
NW Atlantic
Kioti CK2610HST
Hello folks,
I tried removing my loader for the first time over the weekend and found I could not lower the kickstands. I've never removed the loader in the 3 years I've had the tractor, and my last machine was a Deere 1025R with their auto-park, so I'm not sure if I'm missing a step or what, but I'd rather be safe than sorry.
I read the manual, I've watched some videos, and it seems like the kickstands should just be dropping down, that I should be able to just go ahead and pull them down into the proper position. They will not budge. I figure I'll try again in the near future, but before I try to strong arm it, am I missing something?
/ KL4030C loader kickstands #2
Is that the spring loaded style? Which you slide the stand off the hook then pull out. Or the pin style? Where you need to remove the pin?
For some reason, I can't no longer access the Michigan Iron Equip website to check the parts catalogues from this side of the pond.
Pretty sure it's on a spring load.
All the videos I can find are for the KL4030, but I am pretty sure it's the same setup.
/ KL4030C loader kickstands #4
Looks like you have to pull on the end plate and not on the entire kickstand like I said before.
Wondering if some love taps would let it slide. Probably just stuck from not being used, ever.
The end plate being the unpainted metal foot? I tried pulling from that, but I must be doing this wrong.
/ KL4030C loader kickstands #6
Yes. That's what actually slides off the hook to let the kickstand come down. At first, I thought it was the entire kickstand that slid.
You can try loosening that bolt a little bit and see if it helps. Wondering if the dealer got it a bit too tight to prevent any rattle while using the tractor.
I'm going to have to give it another good look! Thank you for the help.
I feel so damn foolish; anyhow, I got it! :ROFLMAO:
John Deere 148 Loader with Brackets (A65640)
John Deere 148...
VERSATECH 66" GRAPPLE RAKE (A64277)
VERSATECH 66"...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
WinPower PTO Generator (A66408)
WinPower PTO...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
